이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace your GPU heat sink.
필요한 것
Unplug your iMac's AC cord along with any peripheral devices.
Lay your iMac face-down on a soft, clean surface as shown.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door.
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
In the proceeding steps, you will disconnect the following cables:
SD Board
Left/Right Speaker and Microphone
Audio Port
Wi-Fi Antenna
Right Temperature Sensor, Bluetooth/Ambient Light Sensor/Camera/Left Temperature, and Hard Drive Fan
CPU Fan/Ambient Temperature and Power Button
IR Sensor
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm fine-threaded screws
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
Remove the strip of tape securing the GPU thermal sensor cable to the logic board.
Remove the four 6.5 mm T8 Torx screws securing the GPU heat sink to the GPU.
It may be necessary to use a #1 screwdriver to hold the sockets on the GPU heat sink stationary as you loosen the T8 Torx screws.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 2개
I have already completed this guide twice. The first "Bake", we were in quarantine due to the Covid-19 Pandemic. But after performing the repair, my computer worked perfectly for 2 years and 7 months. Usually they say it lasts 2 and a half years. I got lucky. Last week, it happened again. I followed the guide again, this time with more security and knowledge, but I came across defective parts due to time. Two of them caused me problems and more work. First a cable from the Airport antenna, the one with the single stripe, broke right at the connector and I had to solder the connector to the cable to try to fix it. I managed, but I confess that I would have liked to change this cable. The second thing, and here I would like some advice, was that the socket where the fan cable fits to cool the ODD (in my case I removed it and put an SSD HD) is defective and now this fan is not working and this worries me.
Fredy Schw - 답글
I installed the "Macs Fan Control" App. And 15 minutes ago, it showed the temperature in the "Optical Drive" of 70º C, as well as in the "Platform Controller Hub Die", everything working in "Auto" mode. I changed it to "Full Blast" and it dropped to 45º C, but this way the fans work desperately and make a lot of noise, however it doesn't heat up the iMac very much. I switched to 3000 RPM (a little less noisy) and the temp stayed at 55 RPM. As the ODD fan is defective, it marks 0 RPM.
Fredy Schw - 답글
