소개
Prereq only guide
필요한 것
Remove the two T8 Torx screws securing the upper bracket to the hard drive.
Remove the upper bracket from the hard drive.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Yes, but how do I open the case to get to the drive? Where do the suction cups come in? What is the EMI foam for?
This guide is missing several steps.
Hi! You have somehow stumbled upon a prerequisite guide that is improperly labeled. This guide is supposed to be used in part with a larger guide.
You can find the complete guide here. Sorry about the confusion!
Do I do anything with this with regards to the new drive?
jinnifer douglass - 답글
