소개
Use this guide to replace the sleep light/IR board.
도구
부품
지정된 부품이 없습니다.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Pull the IR board connector toward the top of the iMac to disconnect it from the logic board.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
