주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iMac Intel 27" 2012-2015 Adhesive Strips Replacement
필요한 것
  1. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Determine which adhesives you have: 1 단계, 이미지 1/1
    • Before you begin, make sure you have the right adhesive strips:
    • The 2012-2015 iMac adhesive strips do not have a microphone cutout and are numbered 11, 12, 13, 14, 15, and 16.
    • Do not install these adhesives on iMacs newer than 2015. Without modifications, the adhesive will block the microphone hole.
    • If your strips are numbered 16, 21, 22, 23, 25, and 26, follow the 2012-2019 iMac adhesive guide instead.
  2. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Stabilize the iMac: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iMac Intel 27" Cardboard Service Wedge
    구매
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iFixit cardboard service wedge.
    • Follow these assembly directions to put the service wedge together.
    • If you are not using an iMac service wedge, be very careful when installing and working behind the display—it can easily fall out and break if the iMac moves unexpectedly.
    Where is the adhesive numbered?
    Julien Dal Col - 답글
  3. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Remove the old adhesive: 3 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Remove the old adhesive: 3 단계, 이미지 2/2
    • Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure.
    • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
    • Peel off the adhesive strips using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
    • After all the old adhesive is removed, carefully clean the surface with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
    • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
  4. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Lay out the adhesive strips: 4 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Lay out the adhesive strips: 4 단계, 이미지 2/2
    • Lay out the adhesives strips beforehand so you won't accidentally install a strip in the wrong place:
    • Strip 11 on the top left
    • Strip 12 on the top right
    • Strip 13 on the right vertical
    • Strip 14 on the bottom right, dark side up
    • Strip 15 on the bottom left, dark side up
    • Strip 16 on the left vertical
    My Strips that came are numbered altogether different. YOU NEED TO FIX THIS
    Stephen Fowler - 답글
    Hi Stephen! I think you may have gotten the newer adhesive strips. Please see step one of this guide to determine which strips you have, and to follow the right guide for your strips.
    Arthur Shi -
  5. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the right side adhesive: 5 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the right side adhesive: 5 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the right side adhesive: 5 단계, 이미지 3/3
    • Start with strip 13, which goes on the right vertical side of the rear enclosure.
    • Before peeling off any backing, line it up along the frame of the iMac to get an idea of where it goes.
    • Peel the short piece of backing off the back of the strip.
  6. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 6 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 6 단계, 이미지 2/2
    • Insert the tip of a spudger into the hole at the top of the strip from the side that still has a backing on it.
  7. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 7 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 7 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 7 단계, 이미지 3/3
    • With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
    • Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pull down against the spudger to ensure the strip is taut, and stick it onto the frame.
  8. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 8 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 8 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 8 단계, 이미지 3/3
    • Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel the longer piece of backing out from behind the strip.
    • If the top half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  9. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 9 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 9 단계, 이미지 2/2
    • Align the lower portion of the strip with the right edge of the frame, and stick it down.
  10. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 10 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 10 단계, 이미지 2/2
    • Use your finger to smooth out the strip. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
    • Do not peel off the front adhesive backing yet.
  11. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the top and left adhesives: 11 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the top and left adhesives: 11 단계, 이미지 2/2
    • Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
    • These three strips have a hole at each end—always use the smaller hole for alignment for more precise placement.
    • On the iMac Intel 27" Retina 5K Display, the top-right strip's blue tabs will not line up with the top antenna in the same way as the non-5K model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
  12. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the bottom adhesives: 12 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the bottom adhesives: 12 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Install the bottom adhesives: 12 단계, 이미지 3/3
    • The two remaining strips (14 and 15) do not have guide holes and are more difficult to place. Before sticking them down, we recommend first setting them in their respective places on the iMac to get comfortable with their placement.
    • Grasp the red pull tab on strip 14 and pull to remove the backing from the strip.
    • Align the strip on the bottom edge of the rear enclosure, directly to the right of the middle screw on that edge.
    • The strip should be positioned such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
    • Run your finger along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
    Note this important point from the next step, which I believe should appear in this step as well, with respect to the right vertical adhesive..
    The strip should be positioned such that the L-bend sits next to the left vertical adhesive. The L-bend should not overlap the left vertical adhesive.
    ace - 답글
    Thanks for the comment! I added the note you pointed out into the step.
    Arthur Shi -
  13. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 13 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 13 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 13 단계, 이미지 3/3
    • Repeat the previous step for strip 15, placing it along the bottom left edge of the iMac.
    • The strip should be positioned such that the L-bend sits next to the left vertical adhesive. The L-bend should not overlap the left vertical adhesive.
    • Once you've applied all the adhesive strips, the iMac should look as shown in the second photo.
  14. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Replace the display: 14 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Replace the display: 14 단계, 이미지 2/2
    • Gently set the display in place over the iMac, and align it carefully.
  15. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 15 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 15 단계, 이미지 2/2
    • Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
    • The tape preserves the display's alignment, and allows you to safely swing the top edge of the display open to access the display cables.
  16. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Test your repair: 16 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Test your repair: 16 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Test your repair: 16 단계, 이미지 3/3
    • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
    • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to step 18.
    • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
    • Flip the display data connector lock down onto the socket.
    • Insert the display power connector into its socket on the logic board.
  17. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 17 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 17 단계, 이미지 2/2
    • Set the display back on the iMac's rear enclosure.
    • At this time, plug in your iMac, power it on, and test your repair before sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
    • When you are finished, shut the iMac down and unplug the power cord before you continue.
  18. iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Seal the iMac: 18 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Seal the iMac: 18 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement, Seal the iMac: 18 단계, 이미지 3/3
    • Verify that your iMac is turned off and unplugged from power before you continue.
    • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
    • Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
    This step should specify removing the film from strip 15, such that repeating the step again for strip 14 in the next step isn’t confusing. Or this step could specify both strip 14 and 15 and step 19 could be deleted entirely.
    ace - 답글
    Good point! I’ll adjust the steps to implement what you suggested.
    Arthur Shi -
  19. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 19 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 19 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 19 단계, 이미지 3/3
    • Reconnect the display power and data cables for the final time.
    • Remember to secure the metal retaining bracket on the display data cable.
  20. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 20 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 20 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 20 단계, 이미지 3/3
    • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
    • Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
  21. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 21 단계, 이미지 1/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 21 단계, 이미지 2/3 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 21 단계, 이미지 3/3
    • Remove one side of the protective film from strip 11 by pulling its tab straight up.
  22. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 22 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 22 단계, 이미지 2/2
    • Remove the other side of the protective film from strip 11.
  23. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 23 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 23 단계, 이미지 2/2
    • Repeat the previous steps to remove the protective films from all the remaining adhesive strips (labeled 11, 12, and 13).
    (labeled 12, 13 and 16)
    euscore@gmail.com - 답글
  24. iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 24 단계, 이미지 1/2 iMac Intel 27" 2012-2015 Adhesive Strips Replacement: 24 단계, 이미지 2/2
    • To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
    • Remove the tape securing the display to the rear enclosure.
    • Check the display after 24 hours to make sure that it is not loose on the iMac.
    This was an excellent guide. Very detailed and comprehensive.
    py - 답글
    Great guide. I just yesterday did my first iMac SSD upgrade and this certainly helped. The strips having glue on both sides were harder to handle than shown but then it was my first time. It’ll be easier next time. The old glue was a little more difficult to remove than suggested but after a number of years setting up I was expecting that. All things considered, this a very good and useful guide. No complaints really; nothing now days is ever 100% as it seems. Biggest lesson was don’t fear doing this. If you’re worked inside computers of any kind you very likely have the necessary skills. I wish I’d swapped the HDD for an SSD a lot sooner.
    David Phillips - 답글
    Great Guide! Just did it! :)
    Mario Günter - 답글
결승점
다른 35명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
254,862 평판
안내서 529개 작성하였습니다
iFixit iFixit 회원
Staff
137 회원들
안내서 17,475개 작성하였습니다
댓글 한 개
Great guide, thanks!
Pro tip: don’t forget to plug in the 2 cables before you close the screen.. not that I had to cut open the iMac and replace the stickers again or something :-).
Tom Vreugdenhil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 59
30일 전: 216
전체 시간: 14,797
