소개
Use this guide to replace the left speaker.
부품
부품은 필요하지 않습니다.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Karl Oakes from Crewe recommends you don’t damage the power button cable.
