주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2639 Left Speaker Replacement
필요한 것
  1. iMac Intel 27" EMC 2639 Left Speaker Replacement, Display: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iMac Intel 27" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
  2. iMac Intel 27" EMC 2639 Left Speaker Replacement: 2 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 2 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
  3. iMac Intel 27" EMC 2639 Left Speaker Replacement: 3 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 3 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 27" EMC 2639 Left Speaker Replacement: 4 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 4 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Continue wheeling the tool up around the top left corner.
  5. iMac Intel 27" EMC 2639 Left Speaker Replacement: 5 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 27" EMC 2639 Left Speaker Replacement: 6 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 27" EMC 2639 Left Speaker Replacement: 7 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 7 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Push the tool around the top right corner of the display.
  8. iMac Intel 27" EMC 2639 Left Speaker Replacement: 8 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 27" EMC 2639 Left Speaker Replacement: 9 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 27" EMC 2639 Left Speaker Replacement: 10 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 10 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
  11. iMac Intel 27" EMC 2639 Left Speaker Replacement: 11 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 11 단계, 이미지 2개 중 2개
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
  12. iMac Intel 27" EMC 2639 Left Speaker Replacement: 12 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 12 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 12 단계, 이미지 3개 중 3개
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
  13. iMac Intel 27" EMC 2639 Left Speaker Replacement: 13 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 13 단계, 이미지 2개 중 2개
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
  14. iMac Intel 27" EMC 2639 Left Speaker Replacement: 14 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 14 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 14 단계, 이미지 3개 중 3개
    • Insert a second card into the gap between the display and frame in the top left corner.
  15. iMac Intel 27" EMC 2639 Left Speaker Replacement: 15 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 15 단계, 이미지 2개 중 2개
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
  16. iMac Intel 27" EMC 2639 Left Speaker Replacement: 16 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 16 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 16 단계, 이미지 3개 중 3개
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 27" EMC 2639 Left Speaker Replacement: 17 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 17 단계, 이미지 2개 중 2개
    • Insert the card back into the top left corner.
  18. iMac Intel 27" EMC 2639 Left Speaker Replacement: 18 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 18 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 18 단계, 이미지 3개 중 3개
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
  19. iMac Intel 27" EMC 2639 Left Speaker Replacement: 19 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 19 단계, 이미지 2개 중 2개
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
  20. iMac Intel 27" EMC 2639 Left Speaker Replacement: 20 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 20 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 20 단계, 이미지 3개 중 3개
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
  21. iMac Intel 27" EMC 2639 Left Speaker Replacement: 21 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 21 단계, 이미지 2개 중 2개
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
  22. iMac Intel 27" EMC 2639 Left Speaker Replacement: 22 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 22 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 22 단계, 이미지 3개 중 3개
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  23. iMac Intel 27" EMC 2639 Left Speaker Replacement: 23 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 23 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 23 단계, 이미지 3개 중 3개
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
  24. iMac Intel 27" EMC 2639 Left Speaker Replacement: 24 단계, 이미지 1개 중 1개
    • If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If there is a wire or cable underneath adhesive tape, always pull the tape off first.
    • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
    • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
  25. iMac Intel 27" EMC 2639 Left Speaker Replacement, Remove the support bracket: 25 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement, Remove the support bracket: 25 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  26. iMac Intel 27" EMC 2639 Left Speaker Replacement: 26 단계, 이미지 1개 중 1개
    • Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
    • How to easily reinstall this support bracket:
    • Position the bracket diagonally.
    • Secure the rightmost screw enough to hold the bracket in place; keep it loose for now so the bracket can pivot.
    • Swing the left side of the bracket down until it sits horizontally in its original position.
    • Starting with the leftmost screw, install and tighten the remaining screws.
  27. iMac Intel 27" EMC 2639 Left Speaker Replacement, Remove the left speaker: 27 단계, 이미지 1개 중 1개
    • Remove two 10 mm T10 screws.
  28. iMac Intel 27" EMC 2639 Left Speaker Replacement: 28 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 28 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 28 단계, 이미지 3개 중 3개
    • Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
    • De-route the cable from the gap between the hard drive and logic board.
    • If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
  29. iMac Intel 27" EMC 2639 Left Speaker Replacement: 29 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 29 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 29 단계, 이미지 3개 중 3개
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
    • Use a spudger to disconnect the power button connector from its socket on the logic board.
  30. iMac Intel 27" EMC 2639 Left Speaker Replacement: 30 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 30 단계, 이미지 2개 중 2개
    • Lift the left speaker straight up, until the power button cable is exposed (about 0.5 inches).
  31. iMac Intel 27" EMC 2639 Left Speaker Replacement: 31 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 31 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 31 단계, 이미지 3개 중 3개
    • Gently de-route the power button cable from its groove in the left speaker.
  32. iMac Intel 27" EMC 2639 Left Speaker Replacement: 32 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 32 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2639 Left Speaker Replacement: 32 단계, 이미지 3개 중 3개
    • Lift the left speaker straight up and remove it from the iMac.
    • If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker.
    • Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
결론
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Walter Galan
705,435 평판
안내서 1,203개를 작성함
1가이드 댓글
Karl Oakes from Crewe recommends you don’t damage the power button cable.
Mark Broomhall - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 37
지난 30일: 132
전체 시간: 2,628
