필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Our teardown iMac Pro sports these "entry-level" specs:
8-core, 3.2 GHz Intel Xeon W processor with Turbo Boost up to 4.2 GHz
32 GB (4 × 8 GB) of 2,666 MHz DDR4 ECC
AMD Radeon Pro Vega 56 GPU with 8 GB of HBM2 memory
27" display with 5120 × 2880 resolution and support for one billion colors (P3 color gamut)
1 TB SSD
Higher-end configurations with up to 18 processor cores will be available in a few weeks' time—if you're looking to spend $13,000 USD or more, that is.
We can hardly contain our excitement as we unbox the magnificent Space Gray accessories—Magic Mouse, Magic Keyboard, and *gasp*
... a black Lightning-to-USB cable.
We'll be back to continue the teardown after we recover from shock and peek out the window for signs of airborne ungulates.
Weirdly, there is still absolutely no provision—dongle or otherwise—for using the Lightning EarPods you get with your iPhone 7, 8, or X on your iMac Pro. Does it seem odd that these incompatible products are coming from, of all places, Apple?
Let's peel back the iMac Pro's fancy fabric wrapping and check the port situation ... just to be sure.
Here's the connectivity sitrep:
3.5 mm headphone jack
SDXC card slot
Four USB 3 ports
Four Thunderbolt 3 (USB-C) ports
10 Gb ethernet port
In case you were wondering, this here is Apple model number A1862.
We tried sticking RAM in these slots on the back. It didn't work.
We're betting the opening procedure will be the same as it was on the iMac 5K—which is to say, if you can use a pizza cutter, you can open an iMac Pro.
With all that glass out of the way, we have a perfect view of the iMac Pro's pristine interior. Say, wouldn't this make a lovely wallpaper for someone?
The first component out is the enormous dual-fan cooler.
Looks like Apple sacrificed the 5K's full-size desktop hard drive (not that you'd want that in a pro machine) to make some room here.
Also sacrificed to the cooling gods: the external RAM access hatch. Sad face.
In exchange, we get a big rear vent and an 80% increase in cooling capacity.
AirPort card functions are consolidated onto the main board—for some unknown reason, Apple ditched the modularity from the 5K model. But we did pick up this funky new retaining clip for the coax cables.
The power supply connects to the logic board by way of not one, not two, but four shiny terminals secured with Torx screws.
It also makes accessing logic board components (apart from the RAM of course) much, much easier. With the power supply tucked back into the rear shell, we can remove the board right away. Let's do that!
With the board out, the first order of business is inspecting the RAM.
There's no way around it: getting here was a major undertaking compared with the dead-simple RAM access hatch on the back of all previous 27" iMacs.
That said, we have a spot of good news: these are standard 288-pin DDR4 ECC RAM sticks, with standard chips on board:
SKhynix H5AN8G8NAFR-VKC 2,666 MHz DDR4
We waste no time in testing a little upgrade: How does four 32 GB modules for a "Maxxed" total of 128 GB sound?
After speedily reassembling everything, we're pleased to report that the result is epic. If you want to try it at home, pick up a Memory Maxxer RAM Upgrade kit.
Back to the business of taking things apart: next up are these twin "SSDs”.
Unlike a standard SSD, which has the controller logic onboard, these raw flash modules only have an interface buffer—the PCIe/NVMe controller lies elsewhere. More on that in a bit.
Under a couple stickers we find some Torx screws. Off they go!
Each blade is designated Apple EMC 3197, model 656-0061A.
Popping the shields off, we encounter some chips:
SanDisk SDRQF8DC8-128G (four per card, two top and two bottom, for a total of 512 GB × 2 = 1024 GB)
Apple 338S00285 power management IC (likely)
Do you want to know what's hiding under this enormous heat sink? So do we. After twirling away a few more Torx screws and tossing aside the mounting springs, we have an answer:
One GPU, which sadly is BGA-soldered in place. And at the opposite side, one workstation-class Xeon processor—not soldered in place.
It might be nice if your $5,000+ workstation could get an upgrade once in a while, rather than a full replacement... right?
We've cleared the board, and it's time for a rundown of the silicon:
Intel Xeon W-2140B (Skylake, 14 nm—likely an underclocked W-2145 to keep the temps in check), 3.2 GHz CPU with Turbo Boost up to 4.2 GHz, paired with what could well be a standard LGA 2066 socket
AMD S5J68 1747 GPEW0333S3 SS63HBN181747US40104 Radeon Pro Vega 56 GPU with integrated 8 GB of HBM2 memory (on-package)
Intel X723D733 E1 05780 (SR3PV?) - likely platform controller hub
AQUANTIA AQtion AQC107-B1-C PCIe to multi-gigabit ethernet controller
Pericom Semiconductors PI3PCIE3412AZHE PCIE 3.0 mux/demux switch
Apple/Universal Scientific Industrial (USI) 339S00428 00012021 Wi-Fi/Bluetooth module
Genesys Logic GL3227A SD 4.0 memory card controller, and Texas Instruments LP8565A13 (likely LED backlight driver)
Flip side:
Cirrus Logic CS42L83 audio/DAC
3x Infineon (formerly Primarion) PXE1110CDM and PXE1610CDN multiphase digital controllers
2x Intel JHL6540 Thunderbolt 3 controller
International Rectifiers IR35217 power stage controller
Macronix MXIC MX25L4006EZNI CMOS serial flash memory
NXP PCAL6524 I/O expander
4x Texas Instruments TAS5764L audio amplifiers
Last but far from least, hovering near the SSD slots, we have two custom Apple chips:
Apple T2 339S00467 layered over SK Hynix H9HKNNNBRUMUVR-NLH LPDDR4
Apple 338S00268—this chip's a bit of a mystery. In our initial excitement we thought it was the rumored A10 Fusion coprocessor, first seen in the iPhone 7, but the package size is too small (roughly 7.4 mm each side). Best guess: this is an Apple/Dialog Semi power management IC.
The downside to all this added functionality and security is a major headache if your iMac Pro ever has to be restored.
With the logic board out of the way, we can extract the 500 Watt power supply.
Manufactured by AcBel Polytech Inc., it accepts 100-240 Volts AC, and packs a little silicon of its own:
STMicroelectronics STD4N80K5 3 A N-channel MOSFET
STMicroelectronics L6599A high-voltage resonant controller
ON Semiconductor NCP1336B current mode controller
Diodes Incorporated AP4310A dual operational amplifier w/ voltage reference
ON Semiconductor NCP1631 2-phase power factor controller
Diodes Incorporated AP2125K-4.2TRG1 300 mA LDO regulator
This iMac's shell is looking a bit bare, but we're not done yet: the "enhanced stereo speakers" are next.
Early reports are that these speakers live up to the hype: they're the best-sounding speakers you can get on a Mac.
...until, we suspect, you can pair it with a Homepod—which should take the whole experience to the next level. We won't know for sure until the Homepod finally hits shelves sometime in 2018. (Is it just coincidence that it looks a bit like a Mac Pro?)
이 단계에 사용된 도구:Mako Driver Kit - 64 Precision Bits$39.95-
We've scoured this chassis for parts, and there's not much left—except for the outrageously awesome spring-loaded hinge mechanism that supports the display.
This is probably the one and only time Apple will sell you a screwdriver and tell you to have at it.
Of course, if you're reading this, there's a good chance you're already fully prepared.
Time to take a closer look at that display. Turns out it uses the same display panel we found in the iMac 5K: LG Display model LM270QQ1.
We peel up the long strip of shielding along the bottom to reveal the chips:
Texas Instruments NH245 8-Bit Dual-Supply Bus Transceiver
Texas Instruments BUF16821 Programmable Gamma-Voltage Generator and Vcom Calibrator
Parade Technologies DP665 LCD Timing Controller
Texas Instruments TPS54320 3A synchronous step-down SWIFT™ converter
Texas Instruments TPS65168 High Resolution Fully Programmable LCD Bias IC for TV
That's a wrap friends. Time to reassemble this beast with some fresh thermal paste and see how it fares as a gaming rig.
In case you were wondering: Yes, it goes back together just fine. We'll have a step-by-step upgrade guide for you soon!
- The RAM and CPU are both modular, meaning repairs and upgrades are a go—despite what Apple tells you.
- The dual SSDs are modular, but custom-made by Apple, complicating replacement.
- Cutting the tape to open the iMac isn't too hard (with the right tools), but it must then be replaced to complete any repair.
- Key replaceable components are buried behind the logic board, requiring a lot of disassembly for access.
- The loss of the external RAM access hatch makes for much more challenging upgrades compared with the 27" iMac 5K.
- The GPU is BGA-soldered in place—potentially a major drawback on a "pro" workstation. No easy graphics upgrades are possible, so choose your configuration wisely.
최종 결론
수리 용이성 점수
(10은 가장 쉬운 수리를 뜻합니다)
댓글 101개
OOH FIRST COMMENT! either way, Apples getting closer and closer to the point where a mac will literally be one single part that will not be modular in any way. Apple says they save the environment as much as possible while sweeping the fact that they make their machines as hard to fix as possible under the carpet.
Wow you got here first!
Apple bounces back and forth between more and less modularity with most new architectures. Claiming that there is some obvious trend here is silly and baseless.
Mark -
This comment aged like fine wine with the launch of the M1-based iMacs.
Liquid cooling? SSD in RAID 0?
