주요 콘텐츠로 건너뛰기
iMac Whiteboard
필요한 것
  1. iMac Whiteboard, iMac Whiteboard: 1 단계, 이미지 1/1
    • We start up with an empty case of an iMac.
    • For directions on removing all of the interior components from your iMac, check out the 24" iMac EMC 2111 device page.
    • This procedure should also work on an iMac G5 or early Intel iMac.
  2. iMac Whiteboard: 2 단계, 이미지 1/1
    • Unscrew the case and take the 56x35 whiteboard, check that it fits nicely.
  3. iMac Whiteboard: 3 단계, 이미지 1/1
    • Apply contact cement to the inside borders of the front case. Leave to dry for about 5 minutes.
  4. iMac Whiteboard: 4 단계, 이미지 1/1
    • Place the whiteboard onto the front case and put weight on it.
    • Make sure that the whiteboard touches the lower side of the metal panel.
    • Leave to dry out for a day.
  5. iMac Whiteboard: 5 단계, 이미지 1/2 iMac Whiteboard: 5 단계, 이미지 2/2
    • Mark up 4 lines of 4cm each on the cardboard.
    • Cut up a rectangle and fold to make up a cylinder. Use scotch tape to hold them together.
    • Repeat to get 2 more cylinders.
  6. iMac Whiteboard: 6 단계, 이미지 1/1
    • Glue the cylinders to the back case of the iMac.
    • This is to have some pressure against the whiteboard.
  7. iMac Whiteboard: 7 단계, 이미지 1/1
    • After the contact cement has dried, take out the small contact cement remnants from the board with a box cutter and a plastic tool (as to not damage the whiteboard)
  8. iMac Whiteboard: 8 단계, 이미지 1/1
    • Reassemble your iMac and write something on it.
결론
Very useful mobile whiteboard!
다른 2명이 해당 안내서를 완성하였습니다.
Angela Penaherrera
회원 가입일: 05/06/13
12,574 평판
안내서 5개 작성하였습니다
댓글 4개
Great idea! How about adding an attachment to the bottom of the stand to hold a book open. Maybe use the speaker case cut to size. Affix it using the holes for the RAM access plate.
mayer - 답글
Thats a great idea too! If you add the stand post some pics ^_^
Angela Penaherrera -
Angela, I tried contacting you via twitter, would you click on my icon and email me. This is about my possible relocation to Ecuador .
mayer - 답글
Done! Check your inbox :)
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 8,115
