주요 콘텐츠로 건너뛰기
iOpener Instructions
필요한 것
  1. iOpener Instructions, iOpener Heating: 1 단계, 이미지 2개 중 1개 iOpener Instructions, iOpener Heating: 1 단계, 이미지 2개 중 2개
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iOpener Instructions: 2 단계, 이미지 1개 중 1개
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iOpener Instructions: 3 단계, 이미지 1개 중 1개
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iOpener Instructions, Alternate iOpener heating method: 4 단계, 이미지 2개 중 1개 iOpener Instructions, Alternate iOpener heating method: 4 단계, 이미지 2개 중 2개
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iOpener Instructions, iOpener Instructions: 5 단계, 이미지 3개 중 1개 iOpener Instructions, iOpener Instructions: 5 단계, 이미지 3개 중 2개 iOpener Instructions, iOpener Instructions: 5 단계, 이미지 3개 중 3개
    • Lay the iOpener clear-side down, flat on the edge of the device, over an adhesive seal you wish to heat. The liquid will flatten the iOpener against the surface, ensuring good heat conduction.
    • Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel.
    • At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
    • During the procedure you may need to reheat the iOpener. To prevent overheating the iOpener, always wait until the iOpener has cooled enough to touch safely. Do not microwave the iOpener for more than thirty seconds at a time.
결승점
다른 672명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
512,205 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,600개를 작성함
47가이드 댓글
I bought two of these, and I can't get an iPad 2 to open using the iOpener; I'm going to keep trying, but heads up, it's not as easy as 1-2-3. I'll update if I get it to work.
Kevin McCartney - 답글
I used a flat toaster maker and turned it off and on as required, Fixed my Ipad mini ok.
Chris Newman -
Step 2 says to wait 5 minutes between reheating, step 4 says to wait 3 minutes.
Also, do you sell the "this is a microwave" stickers? xD
Mark Brown - 답글
Did you ever find out where to get those stickers? XD
Aztrinity -
That's just a label printer label using a fancier font, I think.
towo -
댓글 쓰기
조회 통계:
지난 24시간: 135
지난 7일: 980
지난 30일: 3,645
전체 시간: 480,045
