주요 콘텐츠로 건너뛰기
iPad 3 Wi-Fi Power & Volume Button Assembly Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement, Power & Volume Button Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the following screws securing the power & volume button cable to the aluminum frame:
    • Two 5.5mm Phillips #0
    • One 2.6 mm Phillips #0
    • Two 2.6 mm Phillips #0
    • These screws are angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  2. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the piece of plastic covering the volume buttons.
  3. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the single 2.6 mm Phillips #00 screw holding the volume button frame to the aluminum frame.
    • This screw is angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  4. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 4 단계, 이미지 2개 중 1개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Wedge the edge of a plastic opening tool underneath the sleep/wake sensor, being careful to not damage the fragile cable.
    • Move the plastic opening tool around the sensor, releasing the adhesive.
  5. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 5 단계, 이미지 2개 중 1개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Continue sliding the plastic opening tool underneath the power & volume cables, releasing the adhesive.
  6. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 6 단계, 이미지 2개 중 1개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Using the tip of a spudger, release the adhesive underneath the volume button branch of the ribbon cable.
  7. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 7 단계, 이미지 2개 중 1개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Continue sliding the tip of the spudger toward the top of the iPad, releasing the adhesive.
  8. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 8 단계, 이미지 3개 중 1개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 8 단계, 이미지 3개 중 2개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • With the tip of the spudger still underneath the ribbon cable, gently lift the power button out of its socket in the aluminum frame.
  9. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 9 단계, 이미지 2개 중 1개 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Holding the power & volume button cable with with both hands, carefully pull the volume buttons and lock switch from their sockets in the aluminum frame.
    • Lift and remove the power & volume button cable out of the rear aluminum case.
결론
작성자
4다른 기여자 명과 함께
Walter Galan
701,126 평판
안내서 1,203개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 3
전체 시간: 123
