주요 콘텐츠로 건너뛰기
iPad Mini 6 Front Camera Replacement
필요한 것
  1. iPad Mini 6 Front Camera Replacement, Apply tape to a cracked screen: 1 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Apply tape to a cracked screen: 1 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Apply tape to a cracked screen: 1 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Mini 6 Front Camera Replacement, Heat the bottom edge: 2 단계, 이미지 1/1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Front Camera Replacement, Screen removal information: 3 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Screen removal information: 3 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Screen removal information: 3 단계, 이미지 3/3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Front Camera Replacement, Insert an opening pick: 4 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Insert an opening pick: 4 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Insert an opening pick: 4 단계, 이미지 3/3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Front Camera Replacement, Separate the bottom adhesive: 5 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Separate the bottom adhesive: 5 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Separate the bottom adhesive: 5 단계, 이미지 3/3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Front Camera Replacement, Heat the right edge: 6 단계, 이미지 1/1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Front Camera Replacement, Separate the bottom-right corner adhesive: 7 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Separate the bottom-right corner adhesive: 7 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Separate the bottom-right corner adhesive: 7 단계, 이미지 3/3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Front Camera Replacement, Separate the remaining adhesive: 8 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Separate the remaining adhesive: 8 단계, 이미지 2/2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Front Camera Replacement, Reposition the screen: 9 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Reposition the screen: 9 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Reposition the screen: 9 단계, 이미지 3/3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Front Camera Replacement, Unfasten the display cable bracket: 10 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Unfasten the display cable bracket: 10 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Front Camera Replacement, Remove the display cable bracket: 11 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Remove the display cable bracket: 11 단계, 이미지 2/2
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Front Camera Replacement, Disconnect the display: 12 단계, 이미지 1/3 iPad Mini 6 Front Camera Replacement, Disconnect the display: 12 단계, 이미지 2/3 iPad Mini 6 Front Camera Replacement, Disconnect the display: 12 단계, 이미지 3/3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Front Camera Replacement, Remove the screen: 13 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Remove the screen: 13 단계, 이미지 2/2
    • Remove the screen from the frame.
  14. iPad Mini 6 Front Camera Replacement, Disconnect the battery: 14 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Disconnect the battery: 14 단계, 이미지 2/2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Mini 6 Front Camera Replacement, Unfasten the front camera shield: 15 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Unfasten the front camera shield: 15 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
  16. iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: 16 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: 16 단계, 이미지 2/2
    • Use the tip of a spudger to pry up and disconnect the volume button board's coaxial cable.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  17. iPad Mini 6 Front Camera Replacement, Unfasten the volume button board's coaxial cable: 17 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Unfasten the volume button board's coaxial cable: 17 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the 1 mm screw securing the volume button board's coaxial cable to the frame.
  18. iPad Mini 6 Front Camera Replacement, Reposition the coaxial cable: 18 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Reposition the coaxial cable: 18 단계, 이미지 2/2
    • Use tweezers, or your fingers, to pull the coaxial cable away from the frame, making sure to separate the tape keeping it in place.
  19. iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: 19 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Disconnect the volume button board: 19 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
  20. iPad Mini 6 Front Camera Replacement, Disconnect the front camera: 20 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Disconnect the front camera: 20 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the front camera board's press connector secured to the frame.
  21. iPad Mini 6 Front Camera Replacement, Separate the front camera's adhesive: 21 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Separate the front camera's adhesive: 21 단계, 이미지 2/2
    • The front camera is secured to the frame with light adhesive.
    • Insert the flat end of a spudger between the front camera and the frame.
    • Gently pry up while pushing the spudger deeper into the gap to separate the adhesive.
  22. iPad Mini 6 Front Camera Replacement, Remove the front camera: 22 단계, 이미지 1/2 iPad Mini 6 Front Camera Replacement, Remove the front camera: 22 단계, 이미지 2/2
    • Use tweezers, or your fingers to remove the front camera.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
75,018 평판
안내서 359개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,643개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 31
전체 시간: 259
