소개
Couldn't find a guide to fix a customers iPad so here it is put alot of work into Providing something you can use a reference! Thanks comment please!
필요한 것
Be Sure to turn off iPad by pressing and release the volume up button then volume down.
While Pressing and holding side button until screen turns off.
Just use the slider if you can.
다른 31명이 해당 안내서를 완성하였습니다.
27 Comments
My Face ID no longer works?
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
why not get a new flex cable from ebay or aliexpress
imab -
