도구
지정된 도구가 없습니다.
부품
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Be sure to turn off the iPad by pressing and releasing the volume up button then volume down.
Press and hold the side button until the screen turns off.
Use the slider if you can.
Heating the entire screen will help make it easy to safely remove the screen.
Use a metal pry tool near the least broken shattered side.
Use an ifixit suction cup to pull up the screen so that you can insert a plastic pick.
Apply tape or adhesive over broken glass!
Bust out the metal pry tool lifting broken causing glass to stick to tape working your way around broken side.
Wiggle Jiggle the screen off the adhesive using multiple plastic guitar picks.
On the Top of the screen the proximity sensor front camera has to be disconnected 1st.
Lay screen flat pull it down just enough to use a PH000 Screw drive to remove the safety bracket
Use Flat Ended Spoudger remove the bracken and cable from the Logic board!
Perfect! Now Lift the screen folding it up to the left like so!
Remove 5 PH000 Screws protecting Power Connection and Display Cables
PH000 to Battery Connection
Move Small cable is taped around edges up so you can properly disconnect battery connection
Remove all 3 ribbon cables from logic board with flat headed spudger!
Just a touch of heat don't melt the thing off remove the face ID sensor from Old Screen.
Gently use a tool to get under glued down connection on glass frame of screen!
Remove Bracket off old screen you and move it to new screen
Transfer Cables and Bracket to new screen
Place Screen without adhesive test your screen and face ID
After running test take
Do not clamp recommend to use flat and heavy object
Broken glass on the frame will crack your new screen
다른 25명이 해당 안내서를 완성하였습니다.
댓글 21개
My Face ID no longer works?
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
why not get a new flex cable from ebay or aliexpress
imab -
