주요 콘텐츠로 건너뛰기
iPad mini 4 Wi-Fi Screen and Digitizer Replacement
필요한 것
  1. iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Opening Procedure: 1 단계, 이미지 1개 중 1개
  2. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 2 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 2 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  3. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 3 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  4. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 4 단계, 이미지 1개 중 1개
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  5. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 5 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 5 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 5 단계, 이미지 3개 중 3개
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  6. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 6 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 6 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 6 단계, 이미지 3개 중 3개
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  7. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 7 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 7 단계, 이미지 2개 중 2개
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  8. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 8 단계, 이미지 1개 중 1개
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  9. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 9 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 9 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  10. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 10 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 10 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  11. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 11 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 11 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 11 단계, 이미지 3개 중 3개
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a third pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the third pick in place to prevent the corner adhesive from re-sealing as it cools.
  12. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 12 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 12 단계, 이미지 2개 중 2개
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  13. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 13 단계, 이미지 1개 중 1개
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  14. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 14 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 14 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 14 단계, 이미지 3개 중 3개
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  15. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 15 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 15 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 15 단계, 이미지 3개 중 3개
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  16. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 16 단계, 이미지 1개 중 1개
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  17. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 17 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 17 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 17 단계, 이미지 3개 중 3개
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  18. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 18 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 18 단계, 이미지 2개 중 2개
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  19. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 19 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 19 단계, 이미지 2개 중 2개
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  20. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 20 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 20 단계, 이미지 2개 중 2개
    • Slide the pick around the lower left edge of the iPad.
  21. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 21 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 21 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 21 단계, 이미지 3개 중 3개
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  22. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 22 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 22 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 22 단계, 이미지 3개 중 3개
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  23. iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Battery Connector: 23 단계, 이미지 1개 중 1개
    • To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
  24. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 24 단계, 이미지 1개 중 1개
    • Remove the battery/display cable bracket.
  25. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 25 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 25 단계, 이미지 2개 중 2개
    • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
    • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
  26. iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Display Assembly: 26 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Display Assembly: 26 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Display Assembly: 26 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  27. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
  28. iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Home Button Assembly: 28 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Home Button Assembly: 28 단계, 이미지 2개 중 2개
    • Use the pointed tip of a spudger to flip up the retaining flap on the home button ZIF socket.
  29. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 29 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 29 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 29 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to unplug the home button ribbon cable from the ZIF socket.
    • Continue peeling the ribbon cable up to the EMI shield.
  30. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 30 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 30 단계, 이미지 2개 중 2개
    • Use tweezers to lift the home button control hardware module off the display assembly.
  31. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 31 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 31 단계, 이미지 2개 중 2개
    • Use an opening pick to continue separating the home button ribbon cable from the display assembly.
    • If you use metal tools to separate this cable, you may scratch the iPad glass, removing some paint.
  32. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 32 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 32 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 32 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to pry the home button bracket off the display assembly.
    • When replacing this bracket, it's recommended to use some high-bond tape to secure it.
  33. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 33 단계, 이미지 1개 중 1개
    • Heat an iOpener and lay it over the lower edge of the front panel to soften the adhesive holding the home button in place.
  34. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 34 단계, 이미지 2개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 34 단계, 이미지 2개 중 2개
    • The home button is held in place by a thin, delicate, rubber gasket that is mildly adhered to the front panel.
    • Slowly push the home button up and out of the display assembly to separate the gasket from the front panel.
    • Be careful to not push the gasket past its tearing point. If the adhesive is adequately heated, it will separate from the front panel with some gentle pressure.
  35. iPad mini 4 Wi-Fi Screen and Digitizer Replacement: 35 단계, 이미지 1개 중 1개
    • Remove the home button assembly.
  36. iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Screen and Digitizer: 36 단계, 이미지 3개 중 1개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Screen and Digitizer: 36 단계, 이미지 3개 중 2개 iPad mini 4 Wi-Fi Screen and Digitizer Replacement, Screen and Digitizer: 36 단계, 이미지 3개 중 3개
    • Examine your replacement part, and your original display carefully to be sure they match.
    • Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component.
    • Desolder the six solder pads from the lower left of the display to remove the sensor assembly cable.
결론
다른 29명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Evan Noronha
회원 가입일: 02/05/15
228,066 평판
안내서 168개를 작성함
4가이드 댓글
Not only is that part in step 39 crucial to Smart-Cover function, but the regular sleep/wake function will not work if this isn’t transferred. Wish the replacements were shipped with this part attached, because soldering those tiny points is near impossible to do! Buyer/repairer beware.
Griffin Dampier - 답글
Its better to have reassemble instruction, like where i am going to put the new adhesive?
Richard Genato - 답글
The iFixIt replacement part did not come with adhesive, so I had to reuse the old adhesive that got pulled and torn during removal of the bad screen.
Also, the iFixIt replacement part does not come with the sleep/wake sensor (Step 39). Following my repair, the iPad is no longer capable of going to sleep (neither by the button on top nor through AssistiveTouch), so we have to resort to waiting for the lock screen timer to turn the screen off whenever we’re done using it. I feel the soldering that is required to maintain this functionality (I would imagine it would need a millimeter-diameter drop of solder on six contacts that are then pressed together with the transplanted part to form the bond without solder spilling onto a neighboring contact) is not within the capability of most casual repairers.
If I were to do this repair again, I would find a part that has fresh adhesive and the sleep/wake sensor already attached.
sonnyjohl - 답글
My kit did come with the adhesive, but it's a little tricky to figure out (and there is an embedded link to the adhesive). Needs some more pictures/pointers about re-installing the home button, ended up with a gap in the adhesive near the home button. Also, tips on how to remove shattered glass? Otherwise, thanks for the tutorial, looks new.
CBrewington - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 40
지난 30일: 271
전체 시간: 33,436
