주요 콘텐츠로 건너뛰기
iPhone 13 WiFi Chip Replacement
필요한 것
동영상 개요
iPhone WiFi Chip Repair Solution
  1. iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: 1 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: 1 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Disassemble the iPhone 13: 1 단계, 이미지 3개 중 3개
    • Cover the cameras with protection stickers.
    • Remove the motherboard and split it.
  2. iPhone 13 WiFi Chip Replacement, Test the Wi-Fi Circuits: 2 단계, 이미지 2개 중 1개 iPhone 13 WiFi Chip Replacement, Test the Wi-Fi Circuits: 2 단계, 이미지 2개 중 2개
    • Test the circuits related to the Wi-Fi module to verify that they are normal.
  3. iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: 3 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: 3 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Remove the NAND Chip: 3 단계, 이미지 3개 중 3개
    • It is not possible to read the Wi-Fi serial number (SN) simply by connecting the iPhone to the programming software. Therefore, we will remove the NAND chip.
    • Heat the NAND chip evenly with a hot air gun at 420°C and airflow 80.
    • Pry the NAND chip up.
    • Apply some flux to the soldering pad of the NAND chip.
    • Remove the tins from the soldering pad using braid and a soldering iron.
  4. iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: 4 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: 4 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Use the Luban Programmer: 4 단계, 이미지 3개 중 3개
    • Place the NAND chip in a Luban programmer.
    • Connect the programmer to a PC and open the programming software.
    • Click "Check Factory Data" to read the EcID of the iPhone.
    • Read the EcID from the NAND chip.
  5. iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: 5 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: 5 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Write New Wi-Fi SN Data: 5 단계, 이미지 3개 중 3개
    • Place a new Wi-Fi module into the Luban programmer to write in the Wi-Fi SN.
    • Copy the EcID and select WiFi Operations on the navigation menu.
    • Paste the EcID and click "Check now."
    • Then click "Write now."
    • The Wi-Fi SN has been written into the new Wi-Fi module.
  6. iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: 6 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: 6 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Replace the Wi-Fi Module: 6 단계, 이미지 3개 중 3개
    • Place the signal board onto a fixture.
    • Cover some other components with Kapton tape for protection.
    • Heat the Wi-Fi module with a hot air gun and use a pry knife to remove the edge adhesives.
    • Pry up the Wi-Fi module.
    • Apply some flux to the soldering pad of the Wi-Fi module.
  7. iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: 7 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: 7 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Solder the New Wi-Fi Module: 7 단계, 이미지 3개 중 3개
    • Remove the tins from the soldering joints of the signal board.
    • Remove the tins from the soldering joints of the logic board.
    • Align the new Wi-Fi module carrying the SN to the soldering pad.
    • Solder the new Wi-Fi module with a hot air gun at 380°C and airflow 60.
  8. iPhone 13 WiFi Chip Replacement, Solder the NAND Chip: 8 단계, 이미지 1개 중 1개
    • Solder the NAND chip with a hot air gun at 380°C and airflow 60.
  9. iPhone 13 WiFi Chip Replacement, Testing: 9 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Testing: 9 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Testing: 9 단계, 이미지 3개 중 3개
    • Put the logic board and the signal board into a motherboard-layered test fixture.
    • Connect the iPhone 13 screen cable and the power cable.
    • Use a pair of tweezers to trigger the power-on.
    • The iPhone 13 should power on properly.
    • Go to settings to check if the Wi-Fi function toggle is resumed.
  10. iPhone 13 WiFi Chip Replacement, Reassemble and Done: 10 단계, 이미지 3개 중 1개 iPhone 13 WiFi Chip Replacement, Reassemble and Done: 10 단계, 이미지 3개 중 2개 iPhone 13 WiFi Chip Replacement, Reassemble and Done: 10 단계, 이미지 3개 중 3개
    • Solder the signal board with the logic board.
    • Assemble the iPhone 13 and test the Wi-Fi function.
    • Test and Wi-Fi should be restored and connected properly.
결승점
작성자
1다른 기여자 명과 함께
REWA
회원 가입일: 11/24/20
16,556 평판
안내서 55개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 64
지난 30일: 348
전체 시간: 348
