주요 콘텐츠로 건너뛰기
iPhone 4 Earpiece Speaker Replacement
필요한 것
  1. iPhone 4 Earpiece Speaker Replacement, Rear Panel: 1 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement, Rear Panel: 1 단계, 이미지 2/2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
  2. iPhone 4 Earpiece Speaker Replacement: 2 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement: 2 단계, 이미지 2/2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Earpiece Speaker Replacement: 3 단계, 이미지 1/1
    • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
    • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
  4. iPhone 4 Earpiece Speaker Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
    • Some devices may have two screws, one of which holds down the contact pad which is located above the screw indicated in red in the photo.
  5. iPhone 4 Earpiece Speaker Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Pry from the top and bottom of the connector bracket—there isn't as much of an overhang on the sides, and you may damage the connector.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 4 Earpiece Speaker Replacement: 6 단계, 이미지 1/3 iPhone 4 Earpiece Speaker Replacement: 6 단계, 이미지 2/3 iPhone 4 Earpiece Speaker Replacement: 6 단계, 이미지 3/3
    • Use the clear plastic pull tab to gently lift the battery out of the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 4 Earpiece Speaker Replacement, Logic Board: 7 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement, Logic Board: 7 단계, 이미지 2/2
    • Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
    • This may require a significant amount of force.
    • Remove the SIM card and its holder.
  8. iPhone 4 Earpiece Speaker Replacement: 8 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement: 8 단계, 이미지 2/2
    • Remove the following two screws:
    • One 1.2 mm Phillips
    • One 1.6 mm Phillips
    • Remove the thin steel dock connector cable cover from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the dock connector cable cover with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
  9. iPhone 4 Earpiece Speaker Replacement: 9 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement: 9 단계, 이미지 2/2
    • Use an iPod opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
  10. iPhone 4 Earpiece Speaker Replacement: 10 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement: 10 단계, 이미지 2/2
    • Carefully peel the dock ribbon cable off the logic board and the lower speaker enclosure.
    • Do not use excessive force to peel the dock ribbon cable off the logic board. Doing so may tear the cable.
  11. iPhone 4 Earpiece Speaker Replacement: 11 단계, 이미지 1/1
    • Use a plastic opening tool to pry the lower antenna connector up off its socket on the logic board.
  12. iPhone 4 Earpiece Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the 1.9 mm Phillips screw securing the bottom of the logic board to the inner case.
  13. iPhone 4 Earpiece Speaker Replacement: 13 단계, 이미지 1/1
    • Remove the following five screws securing the Wi-Fi antenna to the logic board:
    • One 2.3 mm Phillips
    • Two 1.6 mm Phillips
    • One 1.4 mm Phillips
    • One 4.8 mm Phillips
    • When re-assembling, start off with replacing the 4.8 mm Philips screw first, then the 2.3 mm. This is to ensure there is no mix-up, and avoid rendering the LCD and digitizer useless.
    • Also make sure to put the long 4.8 mm Philips back in correctly when reassembling. This is the ground for the Wi-Fi antenna and is often the culprit if you are having bad Wi-Fi reception after reassembly.
  14. iPhone 4 Earpiece Speaker Replacement: 14 단계, 이미지 1/3 iPhone 4 Earpiece Speaker Replacement: 14 단계, 이미지 2/3 iPhone 4 Earpiece Speaker Replacement: 14 단계, 이미지 3/3
    • Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
    • Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
    • Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the connector cover with a de-greaser such as Windex. The oils on your fingers have the potential to cause wireless interference issues. Do not clean the connectors themselves with Windex.
  15. iPhone 4 Earpiece Speaker Replacement: 15 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement: 15 단계, 이미지 2/2
    • Use an iPod opening tool to carefully lift the rear camera connector up off its socket on the logic board.
    • Remove the rear camera.
  16. iPhone 4 Earpiece Speaker Replacement: 16 단계, 이미지 1/2 iPhone 4 Earpiece Speaker Replacement: 16 단계, 이미지 2/2
    • Remove the small circular white sticker (warranty sticker and water indicator) covering the screw near the battery pull tab.
    • Remove the 2.4 mm Phillips screw that was hidden underneath the sticker.
  17. iPhone 4 Earpiece Speaker Replacement: 17 단계, 이미지 1/1
    • Use the edge of a plastic opening tool to gently pry the following connectors up and out of their sockets on the logic board:
    • Digitizer cable (pry from bottom)
    • LCD cable (pry from bottom)
    • Headphone jack/volume button cable (pry from top)
    • Top Microphone/sleep button cable (pry from top)
    • Front camera cable (pry from top)
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • When reassembling the device, this standoff sets the height of the Wi-Fi shield removed in step 13. If not torqued down, the shield will be above the plane of the frame and the back will not slide into place in step 2. The shield should be flush with the headphone jack.
    • When reassembling the motherboard, ensure that its edge sits under the circled standoff, otherwise the screws will not fit.
    • When reassembling ensure that the small rubber spacer attached to the top of the motherboard is in place.
    • Without this part, the motherboard could damage the ribbon cables around it.
  18. iPhone 4 Earpiece Speaker Replacement: 19 단계, 이미지 1/1
    • Carefully remove the logic board from the iPhone, minding any cables that may get caught.
    • Be careful not to damage the small gold prong (marked in red, near the top) as it's very fragile.
    • On reassembly, be careful not to trap the lower antenna cable beneath the logic board.
  19. iPhone 4 Earpiece Speaker Replacement, Earpiece Speaker: 20 단계, 이미지 1/1
    • Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the front panel.
    • Remove the earpiece speaker.
결론
다른 261명이 해당 안내서를 완성하였습니다.
Walter Galan
686,717 평판
안내서 1,203개 작성하였습니다
7 댓글
Great instructions. Worked well for my iPhone 4
Shreyas - 답글
Excellent guide. The earpiece speaker grill was clogged after I accidentally spilled coffee on the phone and was unable to hear my calls, oops. Following this guide I was able to clean out the screen with alcohol and compressed air. I couldn't have done it without this great guide. Thanks so much to all the authors and editors!!!
T Bell - 답글
amazing guide! thanks for share it with us!
flaviocassilhas - 답글
Has anyone had problems getting the antenna hooked back up. It gave me a real fit. Oh and yes about the note above about making sure the antenna wire is not stuck under the board. Been there, done that. Ha.
Vernon - 답글
I did it!!! carefull with the ribbon on the edge of the board... the Ear Piece from ifixit is too expansive as the prices of parts. The quality is not too good as the original too i think.
Bruno Loli - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 60
전체 시간: 444,335
