소개
This guide shows how to remove the two bottom Pentalobe screws on the iPhone 4.
필요한 것
Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
다른 431명이 해당 안내서를 완성하였습니다.
3 댓글
What do you do when you strip a screw
I also think I stripped one of the pentalobe screws,one came off the other was a problem from the start. How do you deal with a stripped pentalobe screw?
Hey there! Our Answers forum has a lot of great solutions to this problem! Check out these posts 3.6 mm Pentalobe screw is stripped, What to do when my iPhone pentalobe screws are stripped?, How can I remove a striped pentalobe screw? Good luck!
