주요 콘텐츠로 건너뛰기
iPhone 4 Vibrator Replacement
필요한 것
  1. iPhone 4 Vibrator Replacement, Rear Panel: 1 단계, 이미지 2개 중 1개 iPhone 4 Vibrator Replacement, Rear Panel: 1 단계, 이미지 2개 중 2개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
  2. iPhone 4 Vibrator Replacement: 2 단계, 이미지 2개 중 1개 iPhone 4 Vibrator Replacement: 2 단계, 이미지 2개 중 2개
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Vibrator Replacement: 3 단계, 이미지 1개 중 1개
    • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
    • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
  4. iPhone 4 Vibrator Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
    • Some devices may have two screws, one of which holds down the contact pad which is located above the screw indicated in red in the photo.
  5. iPhone 4 Vibrator Replacement: 5 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Pry from the top and bottom of the connector bracket—there isn't as much of an overhang on the sides, and you may damage the connector.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 4 Vibrator Replacement: 6 단계, 이미지 3개 중 1개 iPhone 4 Vibrator Replacement: 6 단계, 이미지 3개 중 2개 iPhone 4 Vibrator Replacement: 6 단계, 이미지 3개 중 3개
    • Use the clear plastic pull tab to gently lift the battery out of the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 4 Vibrator Replacement, Vibrator: 7 단계, 이미지 1개 중 1개
    • Remove the following two screws securing the vibrator to the inner frame:
    • One 6 mm Phillips
    • One 1.4 mm Phillips
  8. iPhone 4 Vibrator Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the vibrator from the inner case.
결론
다른 133명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
11다른 기여자 명과 함께
Walter Galan
706,070 평판
안내서 1,203개를 작성함
6가이드 댓글
I did it without removing the battery. It was no problem at all, but it might help cause you don't the issue with the connector.
marclaudi - 답글
yep me too... removing the battery isnt nessecary.
thx for this helpfull guide!! was a peace of cake
Frank -
I agree with marclaudi. you can go from page 1 to page 3 since the battery can stay in the phone and still be able to remove the motor
Andreas Nicolaou - 답글
Easy breezy!! Don't need to remove battery! Just turn the phone off first. Took about 5 mins.
Jason White - 답글
Very helpful! Replaced mine in under 5 min without removing the battery. Thanks!
aka - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 57
지난 30일: 301
전체 시간: 158,325
