주요 콘텐츠로 건너뛰기
iPhone 5 Screen Replacement
필요한 것
동영상 개요
  1. iPhone 5 Screen Replacement, Taping the display glass: 1 단계, 이미지 1/3 iPhone 5 Screen Replacement, Taping the display glass: 1 단계, 이미지 2/3 iPhone 5 Screen Replacement, Taping the display glass: 1 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5 Screen Replacement, Remove the Pentalobe screws: 2 단계, 이미지 1/1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. iPhone 5 Screen Replacement, How to prevent display separation: 3 단계, 이미지 1/3 iPhone 5 Screen Replacement, How to prevent display separation: 3 단계, 이미지 2/3 iPhone 5 Screen Replacement, How to prevent display separation: 3 단계, 이미지 3/3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 Screen Replacement, Starting the iSclack Opening Procedure: 4 단계, 이미지 1/3 iPhone 5 Screen Replacement, Starting the iSclack Opening Procedure: 4 단계, 이미지 2/3 iPhone 5 Screen Replacement, Starting the iSclack Opening Procedure: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iSclack
    $24.99
    구매
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5 that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip to Step 6.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  5. iPhone 5 Screen Replacement, Finishing the iSclack Opening Procedure: 5 단계, 이미지 1/2 iPhone 5 Screen Replacement, Finishing the iSclack Opening Procedure: 5 단계, 이미지 2/2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on Step 9.
  6. iPhone 5 Screen Replacement, Manual Opening Procedure: 6 단계, 이미지 1/1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  7. iPhone 5 Screen Replacement, Start lifting the front panel assembly: 7 단계, 이미지 1/1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  8. iPhone 5 Screen Replacement, Detaching the front panel side clips: 8 단계, 이미지 1/1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  9. iPhone 5 Screen Replacement, Opening up the phone: 9 단계, 이미지 1/3 iPhone 5 Screen Replacement, Opening up the phone: 9 단계, 이미지 2/3 iPhone 5 Screen Replacement, Opening up the phone: 9 단계, 이미지 3/3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 5 Screen Replacement, Removing the battery connector bracket screws: 10 단계, 이미지 1/1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  11. iPhone 5 Screen Replacement, Removing the battery connector bracket: 11 단계, 이미지 1/1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 5 Screen Replacement, Disconnecting the battery connector: 12 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  13. iPhone 5 Screen Replacement, Removing the front panel assembly cable bracket screws: 13 단계, 이미지 1/1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  14. iPhone 5 Screen Replacement, Removing the front panel assembly cable bracket: 14 단계, 이미지 1/2 iPhone 5 Screen Replacement, Removing the front panel assembly cable bracket: 14 단계, 이미지 2/2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  15. iPhone 5 Screen Replacement, Disconnecting the front panel assembly cables: 15 단계, 이미지 1/3 iPhone 5 Screen Replacement, Disconnecting the front panel assembly cables: 15 단계, 이미지 2/3 iPhone 5 Screen Replacement, Disconnecting the front panel assembly cables: 15 단계, 이미지 3/3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5 Screen Replacement, Separating front panel assembly and rear case: 16 단계, 이미지 1/1
    • Remove the front panel assembly from the rear case.
결론
다른 888명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
503,085 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 38개
My brother in-law had water damage to his screen and the carrier was going to charge him and arm and a leg for a new phone so I ordered the complete display assembly from right here on iFixit that came with all the necessary tools. Took me a little over 5 minutes between repairing and chit chat to finish. It was a really easy repair and my brother in-law was never happier to have his phone back at a fraction of the cost the carrier was quoting.
lattestonetech24 - 답글
Thanks for your guide for replace new touch screen
i had save one tiny screw from inside assembally :) :) :)
nilesh2411 - 답글
My display didn't shut down when i have a call and i put the phone near my ear! I plug my broken display and it work well but not the new one...please someone help! btw thanks for the guide and for the fast delivery
PENI Teuarii - 답글
I know you posted this awhile ago, but if anyone else is wondering, how to fix the issue where the display won't turn off while on a phone call, You MUST transfer over the small plastic retaining brackets from the old display, and put them in the correct position! By correct position, I mean the two small transparent points need to line up with the receptors on your iPhone's front panel assembly (Camera, light sensor, mic).
Max Rysdon -
This one is for Max:
Max, can you explain better what you mean by plastic retaining brackets? I'm about to swap my screen out and I wanna be able to do this
u60n0ness -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 125
30일 전: 548
전체 시간: 461,213
