이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to remove or replace your GSM iPhone's SIM card and tray.
필요한 것
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press the SIM card eject tool inwards to eject the tray.
This may require a significant amount of force.
다른 42명이 해당 안내서를 완성하였습니다.
댓글 2개
How would you replace the sim card try if the tray is jammed? Is there a way to open up the phone and replace it internally?
You can try opening the phone and removing the SIM eject lever, or seeing if its obstructed somehow, with this guide. good luck!
