주요 콘텐츠로 건너뛰기
iPhone 6 Plus Pentalobe/펜타로브/별나사 교체
필요한 것
  1. iPhone 6 Plus Pentalobe/펜타로브/별나사 교체, Pentalobe/펜타로브/별나사: 1 단계, 이미지 1/1
    • iPhone을 분해하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 끄세요.
    • Lightning 커넥터 옆에 위치한 3.6mm-길이 P2 Pentalobe/펜타로브/별나사 두 개를 풀어주세요.
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - 답글
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - 답글
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - 답글
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - 답글
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - 답글
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
결론
기기를 다시 조립하려면 이 지침을 역순으로 따르세요.
다른 42명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Walter Galan
694,695 평판
안내서 1,203개 작성하였습니다
댓글 한 개
Very simple and to the point. Thank you.
Americo Garcia Jr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 45
전체 시간: 16,365
