이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
One 2.1 mm Phillips #00 screw
One 1.7 mm Phillips #00 screw
Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
Pull the power button switch out of its recess on the rear case with a pair of tweezers.
