주요 콘텐츠로 건너뛰기
iPhone 6s Plus Speaker Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPhone 6s Plus Speaker Replacement, Speaker: 1 단계, 이미지 2개 중 1개 iPhone 6s Plus Speaker Replacement, Speaker: 1 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
  2. iPhone 6s Plus Speaker Replacement: 2 단계, 이미지 2개 중 1개 iPhone 6s Plus Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
  3. iPhone 6s Plus Speaker Replacement: 3 단계, 이미지 2개 중 1개 iPhone 6s Plus Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the three Phillips screws securing the Lightning connector bracket:
    • Two 3.5 mm screws
    • One 2.7 mm screw
    • Remove the bracket.
  4. iPhone 6s Plus Speaker Replacement: 4 단계, 이미지 2개 중 1개 iPhone 6s Plus Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
  5. iPhone 6s Plus Speaker Replacement: 5 단계, 이미지 2개 중 1개 iPhone 6s Plus Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
  6. iPhone 6s Plus Speaker Replacement: 6 단계, 이미지 3개 중 1개 iPhone 6s Plus Speaker Replacement: 6 단계, 이미지 3개 중 2개 iPhone 6s Plus Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
    • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
    • Be sure to re-tighten this screw during re-installation.
    • If the cable snags near the SIM reader, it's likely caught on the SIM tray ejection mechanism. Use the point of a spudger to slide the plastic rod out of the way.
    • During re-installation, be sure to route the antenna cable underneath the logic board corner.
    • During reassembly, you can also re-insert the SIM card tray after re-routing the antenna cable.
    • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
  7. iPhone 6s Plus Speaker Replacement: 7 단계, 이미지 2개 중 1개 iPhone 6s Plus Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the six Phillips screws securing the speaker to the rear case:
    • One 2.5 mm screw
    • Two 2.7 mm screws
    • One 1.5 mm screw
    • One 1.7 mm screw
    • One 2.6 mm screw securing the speaker to the bottom edge of the rear case.
  8. iPhone 6s Plus Speaker Replacement: 8 단계, 이미지 3개 중 1개 iPhone 6s Plus Speaker Replacement: 8 단계, 이미지 3개 중 2개 iPhone 6s Plus Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
    • Pry gently to loosen the speaker module.
    • Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
결론
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
283,072 평판
안내서 587개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,537개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 176
