이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Follow the steps in this guide to replace the rear-facing iSight camera in your iPhone 6s Plus.
필요한 것
동영상 개요
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
이 단계에 사용된 도구:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
다른 127명이 해당 안내서를 완성하였습니다.
댓글 35개
really useful.
Great instructional video which saw me through the entire disassembly of my phone, and then clear and concise enough steps on the page to help me put it back together after installing the new camera. Thank you!!!!
chyke_dawg - 답글
I completed this repair at the same time as replacing my battery and headphone/lightening jack assembly. The problem I was experiencing with my camera was jittery video and unusable photos. The stabilization gimbal had died, though I am not sure that is the right word for it. It's more like it had an overdose. Anytime I would come to use the camera you could hear a tiny clicking noise as the lens armature shot itself about within its tolerances. Photos were out of focus and jittery, even when taken with the phone completely stable and untouched. I could most of the time just manage to make it take photos to deposit checks by holding the phone horizontally and in very bright sunlight, sometimes tapping the phone until the clicking noise stopped. Videos would hunt for focus and look as though I was actively shaking the camera, no matter what. Sometimes it was worse than others. Replacing this assembly completely fixed all issues.
Michael, you might have been interested to know that the focusing problems you experienced are chronic in the iPhone 6 Plus and Apple has created a repair program. You might have found this page useful if your serial number was eligible. https://www.apple.com/support/iphone6plu...
Micheal, I am having that same problem as well! Good to know that replacing it fixes it!
Talon, the repair program Apple has is only for the 6 plus not the 6s plus.
