주요 콘텐츠로 건너뛰기
iPhone 7 Display Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPhone 7 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1/3 iPhone 7 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2/3 iPhone 7 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Display Assembly Replacement: 2 단계, 이미지 1/3 iPhone 7 Display Assembly Replacement: 2 단계, 이미지 2/3 iPhone 7 Display Assembly Replacement: 2 단계, 이미지 3/3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  3. iPhone 7 Display Assembly Replacement: 3 단계, 이미지 1/2 iPhone 7 Display Assembly Replacement: 3 단계, 이미지 2/2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: 4 단계, 이미지 1/1
결론
다른 4명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 02/05/15
223,466 평판
안내서 168개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,652
