이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
If your new battery came with adhesive strips already stuck on, skip to Step 7.
Otherwise: If present, remove the small plastic film(s) covering the flat ends of the adhesive strips.
With the battery facing up (battery connector on the right), carefully align the exposed portion of the adhesive strips along the lower edge of the front of the battery, and press them gently into place.
Place the battery face down on a flat surface.
Starting at the pointed end of the adhesive strips, peel off the large blue film covering the strips.
If this happens to you and you got your strips from iFixit, contact us here and we'll send you a replacement on the double.
In the meantime, you can temporarily reassemble your iPhone with a bit of double-sided tape to hold the battery.
Using your fingertip, gently roll the adhesive strips over the bottom edge of the battery, toward the back.
Lay the strips down flat and let them stick to the back of the battery.
Use your fingers or a cloth to press the strips firmly into place all along the back of the battery.
Carefully peel away the remaining piece of film, fully exposing the adhesive strips.
Without sticking the battery down, lower its connector into the iPhone and align it to its socket on the logic board.
Connect the battery.
When the battery is correctly positioned, lay it down in the iPhone and press it firmly into place, allowing the adhesive strips to stick to the rear case.
Be sure to disconnect the battery again before reassembling your iPhone.
다른 1618명이 해당 안내서를 완성하였습니다.
댓글 68개
I had to read these directions thoroughly three times before proceeding as I didn't want to screw it up on the adhesive. Went slow and it worked just fine
I would say jus watch out as you go from step 4 to step 5 - the white adhesive can become slightly detached from the backing as you push it onto the edge of the battery and then around to the back side. Extreme care here! Very good guide and equipment. Galaxy class!
All was good, aside from the adhesive bunched up when I removed the blue backing and it started to separate from the pink backing. I had to just gingerly make sure it was all straight and kept steady like a heart surgeon until I had it smoothed down as best as possible. It all went well, but I was worried I'd end up with a big stuck ball of white adhesive in the middle of the battery plate, making it all uneven and stupid looking.
DiscoDan74 - 답글
What happens if I use a different adhesive than this one?
The iPhone adhesive strips we sell (and the original Apple ones) are special since they have very strong adhesion, but they can be removed easily by pulling on the tabs on the lower edge of the battery. People have had success with our 3M double-sided sticky tape (aka sticker tape), but standard plastic double-sided tape may not have enough strength to hold the battery in place. If you want the strongest adhesive possible, you should use iPhone adhesive strips mentioned above, but if your phone isn't subject to lots of movement, you could get by with some sticker tape.
