주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod Nano 3rd Generation Display Replacement
필요한 것
    1. iPod Nano 3rd Generation Display Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • Please be aware that removing the rear panel from the back of the iPod will cause considerable damage to the rear panel. We highly recommend purchasing an additional rear panel to properly reassemble the iPod.
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      댓글 쓰기
    2. iPod Nano 3rd Generation Display Replacement: 2 단계, 이미지 1개 중 1개
      • The rear panel is secured to the front case by eight clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
      • To free the tabs, they must be pushed toward the center of the Nano. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
      • To aid in visualization, the two clips boxed in red are located closest to the headphone jack.
      댓글 쓰기
    3. iPod Nano 3rd Generation Display Replacement: 3 단계, 이미지 2개 중 1개 iPod Nano 3rd Generation Display Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Jimmy
      $7.95
      • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. This may mar the iPod but a tool like the Jimmy will work better if plastic tools do not.
      • Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, above the dock connector. The tool's edge should point toward the rear panel to prevent any accidental scratching of the anodized aluminum front case.
      댓글 쓰기
    4. iPod Nano 3rd Generation Display Replacement: 4 단계, 이미지 1개 중 1개
      • Insert a small iPod opening tool into the seam on the headphone jack side of the Nano, with the edge of the tool pointing toward the rear panel.
      • Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the the two tabs attached to the rear case, pushing the clips toward the center of the Nano until both have been freed.
      댓글 쓰기
    5. iPod Nano 3rd Generation Display Replacement: 5 단계, 이미지 2개 중 1개 iPod Nano 3rd Generation Display Replacement: 5 단계, 이미지 2개 중 2개
      • The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
      • Repeat the same procedure listed in the previous step to free the three clips along the hold switch side of the Nano.
      댓글 쓰기
    6. iPod Nano 3rd Generation Display Replacement: 6 단계, 이미지 1개 중 1개
      • Insert an iPod opening tool into the gap near the top left corner of the Nano and work to free the three clips along the top edge of the rear panel.
      • After ensuring all tabs are free, separate the two halves of the iPod.
      • The rear panel is now free from the iPod.
      댓글 쓰기
    1. iPod Nano 3rd Generation Display Replacement, Logic Board: 7 단계, 이미지 1개 중 1개
      • With the rear case removed, the back side of your Nano should now look like this.
      댓글 쓰기
    2. iPod Nano 3rd Generation Display Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the following six screws:
      • One 1.8 mm Phillips.
      • Three 1.9 mm Phillips.
      • One 2.4 mm Phillips.
      • One 2.6 mm Phillips.
      댓글 쓰기
    3. iPod Nano 3rd Generation Display Replacement: 9 단계, 이미지 2개 중 1개 iPod Nano 3rd Generation Display Replacement: 9 단계, 이미지 2개 중 2개
      • Using a spudger, flip up the brown click wheel ribbon cable retaining clip.
      • The clip is hinged at the end nearest the edge of the case.
      댓글 쓰기
    4. iPod Nano 3rd Generation Display Replacement: 10 단계, 이미지 1개 중 1개
      • Use the tip of a spudger to slide the click wheel ribbon cable out of its socket.
      • The logic board is still connected to the iPod by the display ribbon cable.
      댓글 쓰기
    5. iPod Nano 3rd Generation Display Replacement: 11 단계, 이미지 2개 중 1개 iPod Nano 3rd Generation Display Replacement: 11 단계, 이미지 2개 중 2개
      • The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board.
      • Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected). Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
      댓글 쓰기
    6. iPod Nano 3rd Generation Display Replacement: 12 단계, 이미지 1개 중 1개
      • Use a spudger to flip up the display ribbon cable retaining clip.
      • The retaining clip is hinged about the end nearest the battery.
      댓글 쓰기
    7. iPod Nano 3rd Generation Display Replacement: 13 단계, 이미지 1개 중 1개
      • Slide the display ribbon cable out of its socket.
      • The logic board is now completely disconnected from the front case.
      댓글 쓰기
    1. iPod Nano 3rd Generation Display Replacement, Display: 14 단계, 이미지 1개 중 1개
      • A layer of adhesive around the perimeter of the display holds it securely to the front case. The following steps require prying up on the display with a spudger to free it from the adhesive.
      • The display is inherently delicate due to its thin glass construction. In the next few steps it is essential to work slowly and gently while prying the display from the front case.
      • Insert a spudger in the gap between the front case and the display near the top right corner. Slowly and gently pry the display up at several points along the top edge of the display, working your way toward the left corner.
      댓글 쓰기
    2. iPod Nano 3rd Generation Display Replacement: 15 단계, 이미지 1개 중 1개
      • Continue prying up slowly and gently on the display, this time starting at the top right corner and working your way down the right side.
      • Repeat this procedure on the left side of the display, working down from the top left corner.
      댓글 쓰기
    3. iPod Nano 3rd Generation Display Replacement: 16 단계, 이미지 2개 중 1개 iPod Nano 3rd Generation Display Replacement: 16 단계, 이미지 2개 중 2개
      • When the adhesive has yielded enough to create a gap large enough to fit your fingers between the display and the front case, lift the display and gently peel off the remaining adhesive to remove it from the front case.
      • Display remains.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 85명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
710,623 평판
안내서 1,203개를 작성함
7가이드 댓글
Hi, i recently purchased a repair kit consisting of a new display and the requred tools to do the job Order #383628 only to find that you sent a PH00 torx driver instead of the required Phillips screwdriver , also after replacing the screen because the backlight had failed i find that the replacement screen backlight does not work either , i would welcom your comments on this please !
otobern - 답글 공유
Never have I seen such ridiculous design. Despite what this blog claims there is no way the blue plastic tool or guitar picks will remove the back cover. The only way I was able to even slightly part the side seam was with a sharp flat bladed screw driver driven in by a clamp - which bent up the aluminum frame. Now using to the blue plastic "tool" (junk) I pretty much destroyed it working it around. The sharp metal back cover just cuts right into it shreds it. Back to metal flat bladed screwdrivers.
Got back over off - but frame no longer straight. Carefully straightened, Replace the battery & re-assembled. Unit beeped - Screen came on and shows cracks and stress marks but no menu.
Because of awful design I destroyed the screen just trying to get the back cover off to simply replace battery.
So - since Apple was so determined not to let me perform a simple battery replacement I am now equally determined NEVER to buy any Apple product again. So much for being a good design company - Total crap.
Richard Hubert - 답글 공유
I used a thin, flat metal 'iSesamo' type pry tool, like this one - slightly thinner than a box cutter blade, and fairly springy (mine didn't have the plastic handle around the middle, but works fine). Getting the back cover open is still difficult, but with this tool I have done it several times without damaging the back casing or the internals.
Sparky - 답글 공유
It’s funny that Chinese companies that make ipod nano clones managed to attach the back case with 2 or 4 tiny screws. Apple also refuses to sell any parts to repair older electronics. Their agenda seems to be” Why would you want to repair an older product when you can just buy a new one?”.
JOhn - 답글 공유
Because adding screws is much cheaper. Plus these were made more then a decade ago. That’s like asking Samsung to sell pieces for a Note 5 or Nokia to sell parts for their Nokia 3310 phone. Devices have advanced more then 8 gigabytes and there’s a lot of places that scrap and sell parts.
Logan Bruh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 121
지난 30일: 491
전체 시간: 127,574
