소개
Use this guide to remove your Nano's belt clip.
부품
부품은 필요하지 않습니다.
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Remove the following five screws:
One 1.7 mm Phillips screw
Four 3.9 mm Phillips screws.
Remove the following three screws:
One black 1.8 mm Phillips screw
Two 1.7 mm Phillips screws
다른 20명이 해당 안내서를 완성하였습니다.
