주요 콘텐츠로 건너뛰기
iPod Shuffle 3rd Generation Battery Replacement
필요한 것
  1. iPod Shuffle 3rd Generation Battery Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Battery Replacement: 2 단계, 이미지 2개 중 1개 iPod Shuffle 3rd Generation Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Battery Replacement, Logic Board: 5 단계, 이미지 1개 중 1개
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
  8. iPod Shuffle 3rd Generation Battery Replacement, Battery: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • The battery on the Shuffle is attached via solder pads with small holes that go through the battery ribbon cable and attach to flat pads on the face of the logic board. In the following steps you will heat each solder pad individually while using a spudger to pry it up from the logic board.
    • DO NOT bridge the connection between the solder pads on the board. Shorts have the potential to ruin the logic board.
    • Beware of overheating the board and the cable. Only hold the tip of the iron against the pad long enough to let the solder melt. Excess heat buildup has the potential to ruin the logic board or melt the ribbon cable.
    • Start working from the right side of the battery ribbon cable. Heat the right solder pad while gently prying up from under the ribbon cable to free it from the board.
  9. iPod Shuffle 3rd Generation Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Repeat the previous step for the remaining solder pad.
    • Once the two connections have been desoldered, lift the old battery off the logic board.
    • For tips on soldering a new battery to the logic board, follow the repairing soldered connections guide.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
41,975 평판
안내서 67개를 작성함
7가이드 댓글
IS THIS DONE ANYWHERE IN cHENNAI-mADRAS sOUTH iNDIA PL INFORM.
Kumaraswami Vallur Sundaresan - 답글
Is this done anywhere in Chennai- Madras South India?
Thanks, it’s very helpful.
taiotp - 답글
Im going to try and replace the battery with a 3rd party battery and was wondering if you knew which side was the positive and negative
Kai Nodera - 답글
Hi where have u got the battery from
Rishii k -
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 70
지난 30일: 330
전체 시간: 64,585
