이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace a malfunctioning battery to juice up an old iPod Shuffle.
필요한 것
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Start working from the right side of the battery ribbon cable. Heat the right solder pad while gently prying up from under the ribbon cable to free it from the board.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 7개
IS THIS DONE ANYWHERE IN cHENNAI-mADRAS sOUTH iNDIA PL INFORM.
Is this done anywhere in Chennai- Madras South India?
Im going to try and replace the battery with a 3rd party battery and was wondering if you knew which side was the positive and negative
Kai Nodera - 답글
Hi where have u got the battery from
Rishii k -
