주요 콘텐츠로 건너뛰기
iPod Shuffle 4th Generation Logic Board Assembly Replacement
필요한 것
  1. iPod Shuffle 4th Generation Logic Board Assembly Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 2 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Logic Board Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
  3. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the rear panel from the Shuffle.
  4. iPod Shuffle 4th Generation Logic Board Assembly Replacement, Logic Board Assembly: 4 단계, 이미지 1개 중 1개
    • If present, remove the thin black moisture seal covering the Shuffle's internals.
    • Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
  5. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 5 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Logic Board Assembly Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the edge of an iPod opening tool to flip up the retaining flap on the control button cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use a pair of tweezers to gently pull the control button ribbon cable out of its socket.
  6. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 6 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Logic Board Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Use an iPod opening tool to gently pry the battery off the adhesive securing it to the front case.
    • Lift the battery out of the front case, being sure not to strain its delicate leads.
  7. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 7 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Logic Board Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the tip of a metal probe into the hole molded into the logic board retainer nearest the logic board.
    • Pry the retainer first away from the front of the front case, then pull it away from the side of the front case.
    • Remove the logic board retainer from the Shuffle.
  8. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 8 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Logic Board Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Use the edge of an iPod opening tool to push the headphone jack down toward the center of the Shuffle.
  9. iPod Shuffle 4th Generation Logic Board Assembly Replacement: 9 단계, 이미지 2개 중 1개 iPod Shuffle 4th Generation Logic Board Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Continue pushing the logic board down away from the top edge of the Shuffle.
    • Pull the logic board out of the front case by the side nearest the ON/OFF button and gently maneuver the headphone jack out of its recess in the front case.
    • Remove the logic board assembly from the Shuffle.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Galan
706,157 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 31
전체 시간: 14,784
