주요 콘텐츠로 건너뛰기
iPod Touch 2nd Generation Rear Panel Replacement
필요한 것
  1. iPod Touch 2nd Generation Rear Panel Replacement, Front Panel: 1 단계, 이미지 1개 중 1개
    • The glass front panel on the second generation Touch has a plastic frame glued both to its outer edge and also under the wide black strips at the top and bottom of the device. The frame also has a rubber strip that surrounds the edge of the glass panel.
    • The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
    • Also, be mindful of the very thin and delicate touch screen ribbon cable (connector location shown in orange) attaching the front panel to the upper left corner of the Touch.
  2. iPod Touch 2nd Generation Rear Panel Replacement: 2 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Gently insert a plastic opening tool, near the volume control buttons, between the plastic surround of the screen and the metal case.
    • Rotate the tool away from the Touch to pry up on the glass panel.
    • The key is to work slowly and gently to avoid breaking internal components.
    • If you are having difficulties using a plastic opening tool. You could try a razor blade, we found it easier to release the clips with one. Please be extremely careful if you take this route!
  3. iPod Touch 2nd Generation Rear Panel Replacement: 3 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Touch.
    • Do not insert the tool and run it down the edge of the front panel. This may damage the front panel and the rubber seal. It is best to work one point, pry up, then remove the tool and reinsert it at the next spot to be pried up.
  4. iPod Touch 2nd Generation Rear Panel Replacement: 4 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Continue prying up the left edge until the top and bottom edges start to lift out of the Touch.
    • Once the top and bottom edges have lifted slightly out of the Touch, use the opening tool to assure the plastic surround is detached from the clips along the inside of the Touch.
  5. iPod Touch 2nd Generation Rear Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Continue the prying procedure, now focusing on detaching the plastic surround from the internal metal clips.
    • Pry along the top edge of the Touch to further separate the front panel from the rest of the device.
  6. iPod Touch 2nd Generation Rear Panel Replacement: 6 단계, 이미지 3개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 6 단계, 이미지 3개 중 2개 iPod Touch 2nd Generation Rear Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Pry up the front panel along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the front panel until it is lifted slightly from the rear panel.
    • Also, ensure that the plastic surround is separated from the clips in the rear panel.
  7. iPod Touch 2nd Generation Rear Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the front panel out of the rear case minding the cable still attaching it near the upper left corner of the Touch.
    • Make sure you DO NOT tear the display's touch screen connector cable. Tearing this will render your display useless.
  8. iPod Touch 2nd Generation Rear Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger (or an opening tool) to pry the touch screen cable connector up off the upper logic board.
    • Now that the front panel is out, check it for damage. If the plastic surround is not flush with the front face of the glass panel, gently peel it off and stick it down.
    • Be careful not to scratch the front panel on the underside of the black portions, as the scratches will be visible once the device is reassembled.
    • Be sure to clean both the face of the display and the inner surface of the front panel, as any dust or fingerprints will be trapped inside the Touch once it is fully reassembled.
  9. iPod Touch 2nd Generation Rear Panel Replacement, Display: 9 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement, Display: 9 단계, 이미지 2개 중 2개
    • Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
    • Pry up along the lower edge of the display enough to grab it with your fingers.
  10. iPod Touch 2nd Generation Rear Panel Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the display up from its lower edge and rotate it toward the top of the Touch.
    • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
  11. iPod Touch 2nd Generation Rear Panel Replacement: 11 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 11 단계, 이미지 2개 중 2개
    • While holding the display with one hand, run an iPod opening tool down the two long edges of the mylar reflector attached to the metal display tray.
    • When it is sufficiently free from the display tray, remove the mylar reflector from the Touch.
  12. iPod Touch 2nd Generation Rear Panel Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the seven Phillips screws securing the metal display tray to the rear panel.
    • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
  13. iPod Touch 2nd Generation Rear Panel Replacement: 13 단계, 이미지 1개 중 1개
    • Lay the display back down into its tray.
    • Remove the final Phillips screw securing the metal tray to the rear panel.
  14. iPod Touch 2nd Generation Rear Panel Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
    • Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
  15. iPod Touch 2nd Generation Rear Panel Replacement: 15 단계, 이미지 1개 중 1개
    • Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
    • Leave the copper tape attached to the metal display tray.
  16. iPod Touch 2nd Generation Rear Panel Replacement: 16 단계, 이미지 1개 중 1개
    • Use an iPod opening tool to pry the display cable connector up off its socket on the logic board.
  17. iPod Touch 2nd Generation Rear Panel Replacement: 17 단계, 이미지 1개 중 1개
    • Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
    • The display ribbon cable is routed under the metal display tray.
  18. iPod Touch 2nd Generation Rear Panel Replacement, Logic Board: 18 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
    • Remove the metal display tray and set it aside.
    • Lay the battery flat in the rear panel.
  19. iPod Touch 2nd Generation Rear Panel Replacement: 19 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the single Phillips screw securing the gold pressure contact to the logic board.
    • Use a pair of tweezers to lift the Phillips screw out of the logic board.
  20. iPod Touch 2nd Generation Rear Panel Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the following three Phillips screws securing the logic board to the rear panel:
    • One 1.9 mm screw
    • Two 2.3 mm screws
    • The darker screw belongs in the screw hole next to the dock connector.
  21. iPod Touch 2nd Generation Rear Panel Replacement: 21 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 21 단계, 이미지 2개 중 2개
    • Using the tip of a spudger, flip up the control button ribbon cable retaining flap.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • This socket is found under the battery.
  22. iPod Touch 2nd Generation Rear Panel Replacement: 22 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 22 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the control button ribbon cable straight out of its socket.
  23. iPod Touch 2nd Generation Rear Panel Replacement: 23 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 23 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to peel back the protective rubber grommet to reveal a hidden Phillips screw.
    • It is not necessary to completely remove this flap.
    • Remove the hidden Phillips screw.
  24. iPod Touch 2nd Generation Rear Panel Replacement: 24 단계, 이미지 1개 중 1개
    • Remove the two remaining Phillips screws securing the upper logic board to the rear panel.
  25. iPod Touch 2nd Generation Rear Panel Replacement: 25 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to separate the Wi-Fi ribbon cable from the adhesive securing it to the rear panel.
  26. iPod Touch 2nd Generation Rear Panel Replacement: 26 단계, 이미지 1개 중 1개
    • Insert the flat end of a spudger between the metal rear panel and Wi-Fi ribbon cable to further loosen the adhesive along the length of the cable.
  27. iPod Touch 2nd Generation Rear Panel Replacement: 27 단계, 이미지 1개 중 1개
    • Use your hands to continue peeling the Wi-Fi ribbon off the rear panel.
  28. iPod Touch 2nd Generation Rear Panel Replacement: 28 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 28 단계, 이미지 2개 중 2개
    • Pull the small upper portion of the logic board away from the top edge of the Touch to separate it from the rear panel.
    • Allow the board to rest on the outside of the rear panel.
  29. iPod Touch 2nd Generation Rear Panel Replacement: 29 단계, 이미지 1개 중 1개
    • Gently pull the lower portion of the logic board away from the bottom edge of the rear panel.
  30. iPod Touch 2nd Generation Rear Panel Replacement: 30 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement: 30 단계, 이미지 2개 중 2개
    • Carefully lift the logic board assembly out of the rear case, minding any edges that may get caught.
  31. iPod Touch 2nd Generation Rear Panel Replacement, Power/Volume Controls: 31 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws securing the power/volume controls to the rear panel.
  32. iPod Touch 2nd Generation Rear Panel Replacement: 32 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to remove the yellow kapton tape covering the power/volume control ribbon cable.
  33. iPod Touch 2nd Generation Rear Panel Replacement: 33 단계, 이미지 1개 중 1개
    • Lift the power/volume controls out of the rear panel.
  34. iPod Touch 2nd Generation Rear Panel Replacement, Rear Panel: 34 단계, 이미지 2개 중 1개 iPod Touch 2nd Generation Rear Panel Replacement, Rear Panel: 34 단계, 이미지 2개 중 2개
    • Use your finger to push the plastic antenna window through the other side of the rear panel.
    • Remove the plastic antenna window from the rear panel.
  35. iPod Touch 2nd Generation Rear Panel Replacement: 35 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the protective rubber grommet from the bottom left hand corner of the rear panel.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Walter Galan
706,075 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 56,866
