주요 콘텐츠로 건너뛰기
iPod Touch 4th Generation Upper Logic Board Replacement
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. iPod Touch 4th Generation Upper Logic Board Replacement, Upper Logic Board: 1 단계, 이미지 1개 중 1개
    • Remove the following three screws near the top edge of the logic board:
    • One 2.0 mm Phillips screw
    • Two 2.3 mm Phillips screws
  2. iPod Touch 4th Generation Upper Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Use the edge of an iPod opening tool to gently pry, but not remove, the rear-facing camera away from the rear case.
    • Do not attempt to remove the rear-facing camera yet.
  3. iPod Touch 4th Generation Upper Logic Board Replacement: 3 단계, 이미지 2개 중 1개 iPod Touch 4th Generation Upper Logic Board Replacement: 3 단계, 이미지 2개 중 2개
    • Use an iPod opening tool to slightly lift the edge of the logic board next to the battery enough to grab it with your other hand.
    • Do not excessively bend the logic board, as it is very thin and fragile.
    • Be very careful not to lift too much as the volume control ribbon cable is still connected and will tear very easily.
    • While gently lifting the logic board with one hand, use an iPod opening tool to lift the logic board near the copper tape at the logic board's top edge.
    • The logic board will be lifted adequately when the last display assembly connector has cleared the top edge of the rear case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Walter Galan
706,367 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 4,391
