주요 콘텐츠로 건너뛰기
iRobot Roomba 692 Motherboard Replacement
필요한 것
  1. iRobot Roomba 692 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Motherboard Replacement: 2 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement: 2 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Motherboard Replacement: 3 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement: 3 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement: 3 단계, 이미지 3/3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Remove the ten 13.3 mm screws with a Phillips #00 screwdriver.
    • Pull off the outer and inner holders.
  5. iRobot Roomba 692 Motherboard Replacement: 5 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement: 5 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement: 5 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the two 7.4 mm screws that secure the sensor.
    • Once screws are removed slide out the sensor to free it from the slide bumper.
  6. iRobot Roomba 692 Motherboard Replacement: 6 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement: 6 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement: 6 단계, 이미지 3/3
    • Wedge open the top with an opening tool.
    • Wedge the side tabs and middle tabs upward to remove the top lid.
  7. iRobot Roomba 692 Motherboard Replacement: 7 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement: 7 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement: 7 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to unscrew and remove the following screws:
    • Ten 9.6 mm screws.
    • Four 9.4 mm screws.
    • One 9.5 mm screw.
  8. iRobot Roomba 692 Motherboard Replacement: 8 단계, 이미지 1/3 iRobot Roomba 692 Motherboard Replacement: 8 단계, 이미지 2/3 iRobot Roomba 692 Motherboard Replacement: 8 단계, 이미지 3/3
    • Lift up the top cover to access the motherboard.
    • Use the Phillips #00 screwdriver to remove all five 7.6 mm screws that are holding it down.
  9. iRobot Roomba 692 Motherboard Replacement: 9 단계, 이미지 1/2 iRobot Roomba 692 Motherboard Replacement: 9 단계, 이미지 2/2
    • Unplug the wiring by pulling it outward.
    • Once all plugs are off the motherboard it can be removed, repaired, or replaced.
결론
Ruth Oliva
회원 가입일: 11/08/23
217 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-1, Harley Fall 2023 IUPUI, Team 1-1, Harley Fall 2023 회원
IUPUI-HARLEY-F23S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 148
