주요 콘텐츠로 건너뛰기
iRobot Roomba 692 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 692 Side Brush Motor Replacement, Battery: 1 단계, 이미지 1/3 iRobot Roomba 692 Side Brush Motor Replacement, Battery: 1 단계, 이미지 2/3 iRobot Roomba 692 Side Brush Motor Replacement, Battery: 1 단계, 이미지 3/3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Side Brush Motor Replacement: 2 단계, 이미지 1/3 iRobot Roomba 692 Side Brush Motor Replacement: 2 단계, 이미지 2/3 iRobot Roomba 692 Side Brush Motor Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Side Brush Motor Replacement: 3 단계, 이미지 1/3 iRobot Roomba 692 Side Brush Motor Replacement: 3 단계, 이미지 2/3 iRobot Roomba 692 Side Brush Motor Replacement: 3 단계, 이미지 3/3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Side Brush Motor Replacement, Side Brush Motor: 4 단계, 이미지 1/2 iRobot Roomba 692 Side Brush Motor Replacement, Side Brush Motor: 4 단계, 이미지 2/2
    • Remove two gold 12 mm screws from the motor, and lift the motor out.
결론
John Teeguarden
회원 가입일: 11/06/23
73 평판
안내서 1개 작성함
IUPUI, Team 1-1, Harley Fall 2023 IUPUI, Team 1-1, Harley Fall 2023 회원
IUPUI-HARLEY-F23S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 81
