주요 콘텐츠로 건너뛰기
iRobot Roomba 692 Wheels Replacement
필요한 것
  1. iRobot Roomba 692 Wheels Replacement, Battery: 1 단계, 이미지 1/3 iRobot Roomba 692 Wheels Replacement, Battery: 1 단계, 이미지 2/3 iRobot Roomba 692 Wheels Replacement, Battery: 1 단계, 이미지 3/3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Wheels Replacement: 2 단계, 이미지 1/3 iRobot Roomba 692 Wheels Replacement: 2 단계, 이미지 2/3 iRobot Roomba 692 Wheels Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Wheels Replacement: 3 단계, 이미지 1/3 iRobot Roomba 692 Wheels Replacement: 3 단계, 이미지 2/3 iRobot Roomba 692 Wheels Replacement: 3 단계, 이미지 3/3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Wheels Replacement, Wheels: 4 단계, 이미지 1/3 iRobot Roomba 692 Wheels Replacement, Wheels: 4 단계, 이미지 2/3 iRobot Roomba 692 Wheels Replacement, Wheels: 4 단계, 이미지 3/3
    • Remove three gold 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
    • Each drive wheel is labeled left and right.
결론
Demi Muyuela
회원 가입일: 03/14/23
483 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-4, Shaddix Spring 2023 UMass Dartmouth, Team 1-4, Shaddix Spring 2023 회원
UMASSD-SHADDIX-S23S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 44
전체 시간: 345
