주요 콘텐츠로 건너뛰기
iRobot Roomba 890 Charging Contacts Replacement
필요한 것
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: 1 단계, 이미지 2개 중 1개 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: 2 단계, 이미지 1개 중 1개
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: 4 단계, 이미지 2개 중 1개 iRobot Roomba 890 Charging Contacts Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: 5 단계, 이미지 2개 중 1개 iRobot Roomba 890 Charging Contacts Replacement: 5 단계, 이미지 2개 중 2개
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: 6 단계, 이미지 2개 중 1개 iRobot Roomba 890 Charging Contacts Replacement: 6 단계, 이미지 2개 중 2개
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: 7 단계, 이미지 3개 중 1개 iRobot Roomba 890 Charging Contacts Replacement: 7 단계, 이미지 3개 중 2개 iRobot Roomba 890 Charging Contacts Replacement: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: 8 단계, 이미지 2개 중 1개 iRobot Roomba 890 Charging Contacts Replacement: 8 단계, 이미지 2개 중 2개
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: 10 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: 11 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Devin Steiblin
회원 가입일: 03/28/22
442 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G3
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 102
전체 시간: 6,473
