주요 콘텐츠로 건너뛰기
iRobot Roomba Battery Replacement
필요한 것
  1. iRobot Roomba Battery Replacement, Loosen the edge brush screw: 1 단계, 이미지 1개 중 1개
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Battery Replacement, Remove the edge brush: 2 단계, 이미지 2개 중 1개 iRobot Roomba Battery Replacement, Remove the edge brush: 2 단계, 이미지 2개 중 2개
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
  3. iRobot Roomba Battery Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 1개 iRobot Roomba Battery Replacement, Loosen the bottom screws: 3 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
    • Those screws are captive screws and therefore not removable.
  4. iRobot Roomba Battery Replacement, Remove the bottom plate: 4 단계, 이미지 3개 중 1개 iRobot Roomba Battery Replacement, Remove the bottom plate: 4 단계, 이미지 3개 중 2개 iRobot Roomba Battery Replacement, Remove the bottom plate: 4 단계, 이미지 3개 중 3개
    • Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
  5. iRobot Roomba Battery Replacement, Unlatch and remove the battery: 5 단계, 이미지 3개 중 1개 iRobot Roomba Battery Replacement, Unlatch and remove the battery: 5 단계, 이미지 3개 중 2개 iRobot Roomba Battery Replacement, Unlatch and remove the battery: 5 단계, 이미지 3개 중 3개
    • Use your finger to bend the plastic clip and unlatch the battery.
    • Grab the battery with your hand and lift it straight up from inside its recess to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,334 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 49
지난 30일: 178
전체 시간: 7,474
