주요 콘텐츠로 건너뛰기
iRobot Roomba S9 Plus Corner Brush Replacement
필요한 것
  1. iRobot Roomba S9 Plus Corner Brush Replacement, Corner Brush: 1 단계, 이미지 1/2 iRobot Roomba S9 Plus Corner Brush Replacement, Corner Brush: 1 단계, 이미지 2/2
    • Place your Roomba upside down with the brush module facing you.
    • Push the grey tab by the top left corner of the brushes to release the retaining arm.
  2. iRobot Roomba S9 Plus Corner Brush Replacement: 2 단계, 이미지 1/1
    • Lift the retaining arm away from the brushes.
  3. iRobot Roomba S9 Plus Corner Brush Replacement: 3 단계, 이미지 1/1
    • Unscrew the four 11mm Phillips #2 screws holding the vacuum brushes in place.
  4. iRobot Roomba S9 Plus Corner Brush Replacement: 4 단계, 이미지 1/2 iRobot Roomba S9 Plus Corner Brush Replacement: 4 단계, 이미지 2/2
    • Remove the brush module by pulling up from the sides.
  5. iRobot Roomba S9 Plus Corner Brush Replacement: 5 단계, 이미지 1/3 iRobot Roomba S9 Plus Corner Brush Replacement: 5 단계, 이미지 2/3 iRobot Roomba S9 Plus Corner Brush Replacement: 5 단계, 이미지 3/3
    • Unscrew the 7mm Phillips #2 screw holding the corner brush head in place.
  6. iRobot Roomba S9 Plus Corner Brush Replacement: 6 단계, 이미지 1/1
    • Flip over the brush module to access the corner brush motor.
    • Unscrew the 15mm Phillips #0 screws holding the motor in place.
  7. iRobot Roomba S9 Plus Corner Brush Replacement: 7 단계, 이미지 1/3 iRobot Roomba S9 Plus Corner Brush Replacement: 7 단계, 이미지 2/3 iRobot Roomba S9 Plus Corner Brush Replacement: 7 단계, 이미지 3/3
    • Carefully take the motor axle from its housing.
  8. iRobot Roomba S9 Plus Corner Brush Replacement: 8 단계, 이미지 1/2 iRobot Roomba S9 Plus Corner Brush Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the wire connecting the motor using tweezers to pull out the connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lance Brown
회원 가입일: 01/23/20
348 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G3, White Winter 2020 Cal Poly, Team S18-G3, White Winter 2020 회원
CPSU-WHITE-W20S18G3
4 회원들
안내서 9개 작성하였습니다
댓글 2개
Wish there was a way to replace that plastic. Stripped on mine.
Steve Yeung - 답글
Hi!
Is it possible to change just the plastic part where the brush screws in?
They did a really dumb thing and made a metal screw go in a plastic thread so of course, the plastic thread finally gave in.
Piotr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 28
전체 시간: 2,376
