주요 콘텐츠로 건너뛰기
iRobot Roomba i7 Battery Replacement
필요한 것
  1. iRobot Roomba i7 Battery Replacement, Battery: 1 단계, 이미지 1/3 iRobot Roomba i7 Battery Replacement, Battery: 1 단계, 이미지 2/3 iRobot Roomba i7 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, loosen the following screws:
    • 6.27mm-screw in the center of the side brush.
    • Five 6.24mm-screws on the bottom cover.
  2. iRobot Roomba i7 Battery Replacement: 2 단계, 이미지 1/1
    • Carefully remove the bottom cover.
    • If the cover is stuck or hard to remove, use a prying tool to separate it from the device.
  3. iRobot Roomba i7 Battery Replacement: 3 단계, 이미지 1/2 iRobot Roomba i7 Battery Replacement: 3 단계, 이미지 2/2
    • Before removing the battery, make sure that it is not hot or swollen. Swollen lithium-ion batteries release gases that are hazardous for humans.
    • Unclip the original battery and pull upwards to remove it.
    • Use a prying tool if necessary.
    • Close the Roomba app on your mobile.
    • Remove the battery from your Roomba.
    • Hold the start button for 10 seconds.
    • Reinstall the battery and charge for a full cycle. Wait for your Roomba to automatically start itself.
    • Open the mobile app and reconnect to your Roomba.
결론
Battery Disposal: Never dispose of old batteries in the trash. For proper disposal, take it to your local battery recycling facility. You can find one by doing a quick internet search for "battery recycling facility" and including your zip/postal code or city name in the search. Also, check out http://call2recycle.org and plug in your zip/postal code. This will show you all of the registered drop-off locations near you.
다른 4명이 해당 안내서를 완성하였습니다.
Ricardo Pazos Rodriguez
회원 가입일: 01/30/20
488 평판
안내서 3개 작성하였습니다
댓글 5개
Its a shame the battery is so small compared to the cavity. The run time could be greatly expanded by simply putting in a larger battery.
Reid Kersey - 답글
iFixit sells a larger battery that fills the cavity. My i7 used to take 2 charge cycles to clean the main floor of the house. Now it can do it in a single charge. iRobot Roomba i7 Battery Replacement
Justin Vanderhooft -
I bought this battery a bit ago and it would never charge :(
Gary Hulse - 답글
My j7+ says it cannot detect the battery. I have had alot of battery issues where the robot just dies where its at or doesnt charge at the base unless rebooted. Any ideas?
Rick Moore - 답글
What is charging error 19
Rick Moore - 답글
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 103
30일 전: 470
전체 시간: 25,255
