주요 콘텐츠로 건너뛰기
iRobot Roomba i7 Plus Drive Wheel Replacement
필요한 것
  1. iRobot Roomba i7 Plus Drive Wheel Replacement, Side Brush: 1 단계, 이미지 1/3 iRobot Roomba i7 Plus Drive Wheel Replacement, Side Brush: 1 단계, 이미지 2/3 iRobot Roomba i7 Plus Drive Wheel Replacement, Side Brush: 1 단계, 이미지 3/3
    • Flip the Roomba over so the underside is facing up.
    • Remove the 4 mm screw connecting the green side brush to the chassis using a Phillips #2 screwdriver.
    • Remove the green side brush.
  2. iRobot Roomba i7 Plus Drive Wheel Replacement, Back Plate: 2 단계, 이미지 1/2 iRobot Roomba i7 Plus Drive Wheel Replacement, Back Plate: 2 단계, 이미지 2/2
    • Remove the five screws from the underside of the Roomba using a Phillips #2 screwdriver.
    • Pull the back plate up and away from the Roomba to remove it from the device.
  3. iRobot Roomba i7 Plus Drive Wheel Replacement, Drive Wheel: 3 단계, 이미지 1/2 iRobot Roomba i7 Plus Drive Wheel Replacement, Drive Wheel: 3 단계, 이미지 2/2
    • Loosen the two captive screws from each wheel (four in total) using a Phillips #2 screwdriver.
    • Grab each wheel and gently pull them out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Ely
회원 가입일: 03/16/23
531 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 7-6, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-6, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 306
