주요 콘텐츠로 건너뛰기
iRulu AX760 Camera Replacement
필요한 것
  1. iRulu AX760 Camera Replacement, Battery: 1 단계, 이미지 1/3 iRulu AX760 Camera Replacement, Battery: 1 단계, 이미지 2/3 iRulu AX760 Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Camera Replacement: 2 단계, 이미지 1/1
    • Open your tablet.
  3. iRulu AX760 Camera Replacement: 3 단계, 이미지 1/1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Camera Replacement: 4 단계, 이미지 1/2 iRulu AX760 Camera Replacement: 4 단계, 이미지 2/2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. How To Solder and Desolder Connections
  5. iRulu AX760 Camera Replacement: 5 단계, 이미지 1/1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Camera Replacement, Camera: 6 단계, 이미지 1/2 iRulu AX760 Camera Replacement, Camera: 6 단계, 이미지 2/2
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Camera Replacement: 7 단계, 이미지 1/1
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Camera Replacement: 8 단계, 이미지 1/1
    • Pull the camera out of the device.
결론
Jamison Kritz
회원 가입일: 03/20/18
245 평판
안내서 2개 작성하였습니다
IUPUI, Team S6-G4, Baechle Spring 2018 IUPUI, Team S6-G4, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S6G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 106
