주요 콘텐츠로 건너뛰기
iRulu AX760 Screen Display Replacement
필요한 것
  1. iRulu AX760 Screen Display Replacement, Battery: 1 단계, 이미지 1/3 iRulu AX760 Screen Display Replacement, Battery: 1 단계, 이미지 2/3 iRulu AX760 Screen Display Replacement, Battery: 1 단계, 이미지 3/3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Screen Display Replacement: 2 단계, 이미지 1/1
    • Open your tablet.
  3. iRulu AX760 Screen Display Replacement: 3 단계, 이미지 1/1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Screen Display Replacement: 4 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement: 4 단계, 이미지 2/2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. How To Solder and Desolder Connections
  5. iRulu AX760 Screen Display Replacement: 5 단계, 이미지 1/1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Screen Display Replacement, Camera: 6 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement, Camera: 6 단계, 이미지 2/2
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Screen Display Replacement: 7 단계, 이미지 1/1
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Screen Display Replacement: 8 단계, 이미지 1/1
    • Pull the camera out of the device.
  9. iRulu AX760 Screen Display Replacement, Motherboard: 9 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement, Motherboard: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  10. iRulu AX760 Screen Display Replacement: 10 단계, 이미지 1/3 iRulu AX760 Screen Display Replacement: 10 단계, 이미지 2/3 iRulu AX760 Screen Display Replacement: 10 단계, 이미지 3/3
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  11. iRulu AX760 Screen Display Replacement: 11 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement: 11 단계, 이미지 2/2
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  12. iRulu AX760 Screen Display Replacement: 12 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement: 12 단계, 이미지 2/2
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
  13. iRulu AX760 Screen Display Replacement, Screen Display: 13 단계, 이미지 1/1
    • Remove the plastic peel attached to the back of the screen display.
  14. iRulu AX760 Screen Display Replacement: 14 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement: 14 단계, 이미지 2/2
    • Remove the grey wire from the back of the screen display.
  15. iRulu AX760 Screen Display Replacement: 15 단계, 이미지 1/1
    • Insert the plastic spudger underneath the screen display and lift.
  16. iRulu AX760 Screen Display Replacement: 16 단계, 이미지 1/2 iRulu AX760 Screen Display Replacement: 16 단계, 이미지 2/2
    • Continue lifting the screen by hand and pull it out until it is completely removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jamison Kritz
회원 가입일: 03/20/18
245 평판
안내서 2개 작성하였습니다
IUPUI, Team S6-G4, Baechle Spring 2018 IUPUI, Team S6-G4, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S6G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 432
