주요 콘텐츠로 건너뛰기
iView-776TPCII Wi-Fi Antenna Replacement
필요한 것
  1. iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Wi-Fi Antenna Replacement: 2 단계, 이미지 2개 중 1개 iView-776TPCII Wi-Fi Antenna Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
  3. iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: 3 단계, 이미지 2개 중 1개 iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: 3 단계, 이미지 2개 중 2개
    • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
  4. iView-776TPCII Wi-Fi Antenna Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wire free from its connection.
결론
작성자
4다른 기여자 명과 함께
Cory Gratzer
회원 가입일: 09/16/15
586 평판
안내서 5개를 작성함
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S2G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 535
