주요 콘텐츠로 건너뛰기
nikon s3700 LCD Display Screen Replacement
필요한 것
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: 1 단계, 이미지 3개 중 1개 nikon s3700 LCD Display Screen Replacement, Removing the Screws: 1 단계, 이미지 3개 중 2개 nikon s3700 LCD Display Screen Replacement, Removing the Screws: 1 단계, 이미지 3개 중 3개
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: 2 단계, 이미지 3개 중 1개 nikon s3700 LCD Display Screen Replacement, Replace LCD: 2 단계, 이미지 3개 중 2개 nikon s3700 LCD Display Screen Replacement, Replace LCD: 2 단계, 이미지 3개 중 3개
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sales Cameraparts4you
회원 가입일: 07/01/16
3,291 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 19
전체 시간: 663
