주요 콘텐츠로 건너뛰기
Démontage du cache arrière du Toshiba NB205 N330PK
영어
프랑스어
3 단계
Disassembling Toshiba NB205 N330PK Back Panels: 0 단계, 이미지 2개 중 1개 Disassembling Toshiba NB205 N330PK Back Panels: 0 단계, 이미지 2개 중 2개
  • Using the bit driver and the Phillips bit, remove both of the panel's retaining screws.
  • With the screws removed, lift the panel in the designated direction, as depicted in photo, for removal.
  • The hard drive is located beneath this cover and is now accessible.
À l'aide d'un tournevis à embout cruciforme, retirez les deux vis qui maintiennent le cache.
Une fois la vis retirée, soulevez le cache dans la direction indiquée, comme montrées sur la photo, pour le retirer.
Le disque dur est situé sous ce cache et est désormais accessible.
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
