주요 콘텐츠로 건너뛰기
why! N131WU Battery Replacement
필요한 것
  1. why! N131WU Battery Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Battery Replacement, Remove the Keyboard: 2 단계, 이미지 3개 중 1개 why! N131WU Battery Replacement, Remove the Keyboard: 2 단계, 이미지 3개 중 2개 why! N131WU Battery Replacement, Remove the Keyboard: 2 단계, 이미지 3개 중 3개
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Battery Replacement, Remove Keyboard Connections: 3 단계, 이미지 3개 중 1개 why! N131WU Battery Replacement, Remove Keyboard Connections: 3 단계, 이미지 3개 중 2개 why! N131WU Battery Replacement, Remove Keyboard Connections: 3 단계, 이미지 3개 중 3개
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Battery Replacement, Remove the upper screws: 4 단계, 이미지 2개 중 1개 why! N131WU Battery Replacement, Remove the upper screws: 4 단계, 이미지 2개 중 2개
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU Battery Replacement, Battery: 5 단계, 이미지 2개 중 1개 why! N131WU Battery Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the five Phillips screws securing the battery.
    • Unplug the power connector and lift the battery out in the direction of the arrows to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
31,564 평판
안내서 264개를 작성함
댓글 한 개
Merci beaucoup, tutoriel très bien fait qui nous a beaucoup aidé !
La Puce A l'Oreille - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 18
전체 시간: 482
