주요 콘텐츠로 건너뛰기
why! N240BU Keyboard Replacement
필요한 것
  1. why! N240BU Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 why! N240BU Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Keyboard Replacement, Access to main components: 2 단계, 이미지 2개 중 1개 why! N240BU Keyboard Replacement, Access to main components: 2 단계, 이미지 2개 중 2개
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU Keyboard Replacement: 3 단계, 이미지 3개 중 1개 why! N240BU Keyboard Replacement: 3 단계, 이미지 3개 중 2개 why! N240BU Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU Keyboard Replacement, The keyboard: 4 단계, 이미지 3개 중 1개 why! N240BU Keyboard Replacement, The keyboard: 4 단계, 이미지 3개 중 2개 why! N240BU Keyboard Replacement, The keyboard: 4 단계, 이미지 3개 중 3개
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  5. why! N240BU Keyboard Replacement: 5 단계, 이미지 3개 중 1개 why! N240BU Keyboard Replacement: 5 단계, 이미지 3개 중 2개 why! N240BU Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the connector circled in red in the direction of the arrow
결론
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
2가이드 댓글
Thanks for the example. But where did you bought the keyboard? i can’t find it.
Marcos - 답글
Dear Sir,
thank you for your request. We are swiss keyboards, which you can order here:
''https://whyopencomputing.ch/fr/laptop-wh...
and we have a French AZERTY here:
''https://whyopencomputing.com/fr/laptop-w...
For other keyboards, please try by your local Clevo supplier.
Best regards.
Felice Suglia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 499
