주요 콘텐츠로 건너뛰기
why! N240BU Motherboard Replacement
필요한 것
  1. why! N240BU Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 why! N240BU Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Motherboard Replacement, The keyboard: 2 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement, The keyboard: 2 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement, The keyboard: 2 단계, 이미지 3개 중 3개
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  3. why! N240BU Motherboard Replacement: 3 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 3 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the connector circled in red in the direction of the arrow
  4. why! N240BU Motherboard Replacement, Access to main components: 4 단계, 이미지 2개 중 1개 why! N240BU Motherboard Replacement, Access to main components: 4 단계, 이미지 2개 중 2개
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  5. why! N240BU Motherboard Replacement: 5 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 5 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  6. why! N240BU Motherboard Replacement, SSD Hard Drive: 6 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement, SSD Hard Drive: 6 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement, SSD Hard Drive: 6 단계, 이미지 3개 중 3개
    • Unscrew the screw circled in red
    • Pull out the M.2 SSD in the direction of the red arrows
  7. why! N240BU Motherboard Replacement, Hard Drive (mass storage): 7 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement, Hard Drive (mass storage): 7 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement, Hard Drive (mass storage): 7 단계, 이미지 3개 중 3개
    • Remove the screw circled in red
    • Lift up the hard drive
    • Remove the hard drive in the direction of the red arrows
  8. why! N240BU Motherboard Replacement, WLAN Card: 8 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement, WLAN Card: 8 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement, WLAN Card: 8 단계, 이미지 3개 중 3개
    • Disconnect the two connectors marked in green
    • Remove the WLAN card
  9. why! N240BU Motherboard Replacement, RAM: 9 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement, RAM: 9 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement, RAM: 9 단계, 이미지 3개 중 3개
    • Press down on the two brackets boxed in red
    • Remove the RAM stick in the direction of the red arrows
  10. why! N240BU Motherboard Replacement, CMOS Battery: 10 단계, 이미지 2개 중 1개 why! N240BU Motherboard Replacement, CMOS Battery: 10 단계, 이미지 2개 중 2개
    • Press with a screwdriver in the red circled area to spread the base of the battery
    • Remove the battery by holding the screwdriver down
  11. why! N240BU Motherboard Replacement, Fan: 11 단계, 이미지 2개 중 1개 why! N240BU Motherboard Replacement, Fan: 11 단계, 이미지 2개 중 2개
    • Remove the two screw circled in red
    • Disconnect the connector boxed in green in the direction of the green arrow
    • Remove the fan by lifting it up
  12. why! N240BU Motherboard Replacement, Motherboard: 12 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement, Motherboard: 12 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement, Motherboard: 12 단계, 이미지 3개 중 3개
    • Lift the retaining flap off of the connector boxed in red.
    • Disconnect the connector boxed in red.
  13. why! N240BU Motherboard Replacement: 13 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 13 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Lift the flap that holds the connector (framed in green)
    • Disconnect the connector (framed in green)
  14. why! N240BU Motherboard Replacement: 14 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 14 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Disconnect the connector marked in red by lifting it up
  15. why! N240BU Motherboard Replacement: 15 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 15 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Disconnect the connector marked in green by pulling it in the direction of green arrows
  16. why! N240BU Motherboard Replacement: 16 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 16 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Disconnect the connector marked in red by pulling it in the direction of the red arrows
  17. why! N240BU Motherboard Replacement: 17 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 17 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Lift the black retaining flap that holds the connector marked in green
  18. why! N240BU Motherboard Replacement: 18 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 18 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 18 단계, 이미지 3개 중 3개
  19. why! N240BU Motherboard Replacement: 19 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 19 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    • Unscrew the five screws circled in green
    • Lift the motherboard by taking it by the radiator as in the second picture
  20. why! N240BU Motherboard Replacement: 20 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 20 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 20 단계, 이미지 3개 중 3개
    • Lift the retaining flap that holds the connector marked in red
  21. why! N240BU Motherboard Replacement: 21 단계, 이미지 3개 중 1개 why! N240BU Motherboard Replacement: 21 단계, 이미지 3개 중 2개 why! N240BU Motherboard Replacement: 21 단계, 이미지 3개 중 3개
    • Lift the retaining flap that holds the connector framed in green
    • Remove the motherboard from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
31,564 평판
안내서 264개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 650
