MacBook Pro 15" Display Components
Grab a toolkit for your MacBook Pro 15" model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" 모델을 선택하십시오:
MacBook Pro 15" (Model A1150) Inverter/iSight Cable
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlight
MacBook Pro 15" (Model A1150) Clutch Cover
Houses the hinges and airport antenna assembly.
MacBook Pro 15" (Model A1150) Antenna Cover
This antenna cover houses the airport antenna assembly compatible with the Model A1150 EMC 2101 15 inch MacBook Pro laptop. Part #922-7279.
MacBook Pro 15" (Models A1150/A1211) Rear Display Bezel
MacBook Pro 15" (Models A1211/A1226) Airport Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1211 or A1226 model 15 inch MacBook Pro laptop.
MacBook Pro 15" (Models A1226/A1260) LED Driver Board
LED Driver Board controls the LED backlight.
MacBook Pro 15" (Models A1226/A1260) Inverter/iSight Cable
MacBook Pro 15" (Model A1260) AirPort Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1260 model Early 2008 15 inch MacBook Pro laptop.
기기 정보
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
Please select your version above for parts and support!
